Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Westinghouse SK-26H240S When set is turned on, there is either white screen or blue screen. It does not power up or display w logo. No channels or menu either.
  • matt101583 May 05, 2009
    i have a 32 inch white westinghouse lcd that has sound but the screen is blue when powered on and doesnt show a picture. looking for any insight as to the problem
  • Anonymous Mar 15, 2014
    manual for sk-26h240s tv
Problem solved...TNX!
Posted on Feb 15, 2008
    New Friend:
I don't have a fix, but here is a workaround:
1) While a picture is displayed, use the channel up/down button to switch to the nearest channel with a different major channel number (i.e. the number before the period is different).
2) Now press the menu key to enter setup and then rescan the channels.
Your TV should now work correctly for a week or two, then the problem will surface again. Repeat this workaround as often as necessary. I hope this helps.
Posted on May 22, 2013
    New Friend:
Umm... can you elaborate on "problem solved" ?
Posted on Feb 18, 2013
Westinghouse 32 inch tv just turns off after 2 or 3 days of use
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 29, 2016 | Westinghouse SK-32H240S Television
Display setting Westinghouse tv sk26h240s
Hi
You can find the user manual here.
http://www.manualslib.com/manual/190215/Westinghouse-Sk-26h240s.html
Aug 05, 2014 | Westinghouse New Original SK26H240S Remote...
Screen freezes and wont come back
Also damaged capacitors can cause a slow dieing effect to the display, from what I have seen during my research efforts to find solution for repairs to computers people have bought to me. I have only seen "dead" display lcd monitors that have repaired ok by replacing the $1 capacitors.
Jan 16, 2013 | Westinghouse SK-26H240S Television
I have a Westinghouse SK-26H240S LCD TV. It is about 3 years old. I never had a problem with it until a few days ago. It turns on but I get no picture or sound. The screen sometimes has some horizontal...
This is definitely a problem with the LCD controller of the tv or the LCD panel itself. However if I were you I would hope that its just the controller(which costs about 50$) and go ahead with the replacement to see if that resolves the problem
Mar 16, 2011 | Westinghouse SK-26H240S Television
When I turn the tv on there is only 4 channels that show up. And I do have the cable pluged in
Run a full channel scan through the menu and the rest should show up as well.
Some TVs also have ability to manually turn off channels, which makes it easier to navigate when using UP and DOWN channel buttons. Instead of going to every single channel available you skip the ones that have been marked for skipping. It's a useful feature, but can get you in trouble.
Once a local hotel called us to repair 5 of their TVs and what turned out was that someone has played a joke on them and disabled all channels from the menu.
http://www.coppelltvrepair.com
Dec 09, 2010 | Westinghouse SK-26H240S Television
Turn set on picture for a few seconds then it
Check to see if you are getting 12vdc feeding the T-CON board. the gray glowing means the backlight is working.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 03, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
White Westinghouse flat screenTV freezes up and hums.
Sometimes if you just press on your overscan button on the remote and make the picture a little bigger or smaller the humming noise and freezing of the picture will actually stop.
Jul 27, 2009 | Westinghouse SK-26H240S Television
19 in blue screen only sound works great
blue screen is the noise mute screen. however the audio is not getting muted and hence the buzzing....meaning the tuner on the TV is not getting locked on to the station/frequency
1. check your antenna if you are using one. Autotune
OR
2. Reconnect coax from the cable box to Tv and autotune.
OR
3.Use the Video out from the cable box and connect it to one of the video inputs on the TV. Switch your Tv to that component. Use the cable box to change channels (Best case scenerio)
Feb 28, 2008 | Westinghouse SK-26H240S Television
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
453 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
