Question about LG WM-2277HW Front Load Washer
Tromm Washer Model # WM2277HW by LG
My Tromm washer will not spin on the rinse cycle. What should I do?
  • 2 more comments
  • jjjjss Mar 01, 2008
    what does ie mean and how to fix it
  • Ezgi Guvercin
    Ezgi Guvercin Oct 27, 2013
    Its easy, all u have to do is.. You know the long tube that lets all the dirty water out? yeah when it lets the water out, place ur palm on it so it cant let any water out, wait for a couple seconds (this should take 10 to 15 seconds) then the washer will start again :)
  • Anonymous Mar 22, 2014
    Rinse cycle is flashing but not emptying
  • Anonymous Mar 30, 2014
    can't change water temp settings on some cycles
    Problem Solver:
  • 10 Answers
Will it spin after it washes if it does not then your belt might be broke
Posted on Feb 12, 2008
  • rodger_nugen
    rodger_nugen Jun 12, 2012
    this model has no belt, most likely it's giving you an LE error code, and this means that the computer's sensor is checking to see if the motor is rotating. Either the sensor isn't working right or (20 $ part) 6501KW2002A there is something bigger going on. The part is usually tried first in order to fix it.
  • rodger_nugen
    No belt on this model.
    6501KW2002A is a sensor that goes out that the computer uses to check to see if the motor is turning. It is a 20 $ part that people try first.
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
I have an lg tromm front load washer. I am getting the IE fault. I have cleaned the inlet screens and drain filter. It gets stuck at the 13 min mark, seems like it just won't go to spin cycle.
LE code mean suds have built up. Using non he (High Efficiency) detergent or too much detergent will cause this error most front loaders use he detergent only there is a he swirl on the container
Let your washer sit idle or 45 minutes.Unplg washer as well
Plug in and turn on as left spin speed select no spin press Start/pause to start a drain only cycle. When cycle is complete remove load. Start a rinse•spin cycle to clean out residue.
If the sud were too much you may have to repeat
Jul 25, 2015 | LG Washing Machines
LG tromm spins on washer,but doesn't on rinse and won't drain
ur confusing me its not suppose to spin first , first it rinses, then drains then spins
Jul 12, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer wont drain lg tromm frontloading washer
You need to isolate the drain pump and check the voltage at the time of the drain cycle. If no voltage is present then you need to check on the control board as it can be a failure of the drive.
If voltage is present but there is no drain action then the valve pump is stuck, choked or faulty.
remove and check: click on : Drain.
Feb 27, 2013 | LG WM2016C
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Loud bang during spin
Unplug it and plug it back in after a min. Try to put it threw a rinse spin cycle. Delicate option has a shorter rinse spin time.
See if it suds up, when you hear it trying to drain lift up the drain hose to the wall. It is the gray tube that has the elbow bend, might (should) be hooked to wall. If it isn't moving a good amount of water the machine isn't draining.
Aug 04, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-2277HW Front Load Washer Logo
1,179 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
