Question about Xerox Phaser 8400DP Thermal Printer
Clogged print head
I have a Xerox Phaser 8400 "solid ink" printer.  Black print head appears to be clogged.  I've run through all the cleaning cycles several times and it seems to only get worse.
The print head costs $800!
Any solutions?????
thanks in advance,
RC
  • valuehunter Feb 12, 2008
    This is GREAT!
    only problem is that the drivers are only compatible with those machines running windows...
    and I have a mac!
    any workarounds??
    many thanks!
    I don't have windows on it; however...
    If I borrowed a windows-based laptop could I run it after installing the xerox software that came with the Phaser??  I presume that I can print from a pc and a mac to the same printer.
    ...Thanks for all your trouble Tryit!
    I will try it and let you know - don't get out your engineering books yet!
    President:
  • 2,072 Answers
What you can try is going onto the Xerox.com site and loading what is call Jet Substitution it will change the ports being used.
That could help.
Load it to your laptop and then run. Sometimes helps.
Unfortunatly that is a very expensive print head.
Posted on Feb 12, 2008
  • Rick Kasper Feb 12, 2008
    A little more info. On Xerox.com select support and drivers.
    Enter Phaser 8400, then drivers and downloads. In specific what you want to run is Jet Snippet Files.
    > JetFix Snippet Files
    Version: NA
    Date: 8/17/2004
    Language: English (US)
    JetFix snippet files. These should only be used if the Eliminate Light Stripes procedure does not clear a blocked printhead jet. The JetFix snippet files perform a special printhead cleaning/jetting function. Read the readme file included before using the JetFix snippets.
    Well isn't that goofy. Do you have a Mac with windows on it that you can load the driver and jet snippet?
    Seems weird that that fix is on some Windows and not Mac, but the Mac OS are supported with drivers, I will look more into it tomorrow when I get back in and have all my engineering notes to look at.
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
How do you fix error "07,010.43:14085" on the Xerox Phaser 8400
The error is normally caused by the print head wiper being stuck to the print head or the print head pivot block being contaminated with spill over ink.
To clean the block you remove the left side cover. There is a stainless steel block about 1 inch by 1 inch about midway back on the lower frame. It would most likely have a lot of yellow ink in it.
If the wiper blade is tacked to the print head, you would remove the right and left cover. then remove the ink loader. ( where you place the ink sticks.). Once you remove the ink loader you are in the print head drum area and would gently detack the blade from the print head, then run the eliminate light stripes in the troubleshooting menu.
Mar 30, 2010 | Xerox Phaser 8400 Laser Printer
What is error code 07,010.43:32309
The print head is not moving freely.
There is s print head block that may be filled up with runoff ink, or the print head wiper blade may be tacked to the print head.
Apr 16, 2009 | Xerox Phaser 8400 Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Clean an 8400
Replace the maintenace kit and then in the menus run eliminate light stripes and eliminate smears.
There really isnt much else to do.
What you do when you run the light stripes and smears modes the machine removes all the ink from the print head, turns on a compressor and blows out the jets on the print head.
There really isn't a "cleaning " procedure as with a laser printer. If the maintenance kit is good, it pretty much maintanes itself.
Jan 06, 2009 | Xerox Phaser 8400 Laser Printer
Hi, we have a big problem
I would guess Orange = light red (magenta) indicating a problem with a clogged ink nozzels on the print head.
So might need an engineer if the cleaning option (on the printer menu) can't fix it.
Cheers
Oct 22, 2007 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400DP Thermal Printer Logo
368 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
