Question about Neff 24 in. S5443X2 Built-in Dishwasher
How to remove bottom panel on front of Hotpoint model HDA 465-01 Dishwasher
Dishwasher has not been used for some time and is not draining. would like to remove front bottom panel to see if all looks ok under machine. Will also be trying to fix problem with draining. Cannot locate any clips or method to remove panel.
Thank you
  • 54 Answers
Two different models one is lean it back two screws hold the complete base on and you just twist the pump off. the other you can access the pump from below the internal filter on the left one torx screw and you can see if there is anything blocking the pump. regards
Posted on Feb 12, 2008
My Hotpoint dishwasher won't drain. What can I do? HDA 3740 Go2SA are the numbers on it
Look for the fill float on a corner of the unit. Does it move freely? Is it waterlogged? This signals filled and empty depending where in the cycle it is.
Mar 12, 2018 | Hotpoint Dishwashers
Dishwasher wont drain
Hi buy the inforamtio you are giving me , I don't know if it is a turnknobb type washer or touch pad, I ti the controler is bad, you do still have power correct ?
Dec 05, 2011 | Hotpoint Dishwashers
Water leaking at the bottom of the door
Tightening the fittings
1 Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
2 Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
3 Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
4 Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine
1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
2 Open the door completely and remove the bottom dish rack.
3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
6 Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door
1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Nov 24, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Where can I get a black door panel for my Hotpoint Dishwasher.Mod # HDA 200x-68ba. I think the part number is EAP 26126
Go to www.applianceart.com they have all kinds of colors and panel options. they have designs, colors, textures, holiday ones, and even stainless steel. www.applianceart.com
Aug 26, 2010 | Hotpoint 24 in. HDA3400G Built-in...
I'm trying to find out info on Hotpoint dishwasher catalog # 40mc20
That number is not a factory Hotpoint model number, you need to get the Hotpoint model number, which starts with #HDA*******(example#HDA1100NWH) then go to www.hotpoint.com and you will find info on the dishwashers.
GOOD LUCK !
Aug 09, 2010 | Hotpoint Dishwashers
Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Mar 15, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Need to replace drain hose how to get access to do this
Hello Oriel7,
I am assuming that your dishwasher is built in and not a portable model. That being the case, and assuming that the drain was originally installed correctly and feeing into your house drain near your kitchen sink, you may need to pull the dishwasher out from between the cabinets. To do that is fairly involved however I would ask why you need to replace your drain hose. If you see a section damaged or leaking then you may be able to remove a section anmd splice another tube to that. If that is not going to solve your problem then you will probably want to gain access to that drain house from the toe kick panel beneath the bottom of the door. That panel should be removable ( depending on the model ) and access to where your drain hose attaches will vary from model to model. If you cannot reach in from the front to remove and replace it, you will need to unhook your dishwasher from the cabinetry and slide it out for access to the connection point. The degree of difficulty doing this will vary from installation to installation and wil be dictated by the way your water supply line is attached as well as how your ac power is applied. Newer methods of bringing ac power to the dishwasher are similar to any other appliance in that the electrician will provide an outlet receptacle that you can plug your dishwasher in to or out of. Older techniques 'hard wire' the power in a junction box in the bottom of the dishwasher and a bot more involved in disconnecting. If that is the method your dishwasher is installed, you will need to remove or disable power to that wiring by swithcing off the appropriate circuit breaker or power disconnect. In any and all cases, the process of removing the dishwasher from bewteen two base cabinets is not very easy. Please elaborate on the reason why you need to replace your drain hose and the method your dishwasher has been installed. If you can provide more details, I can help you resolve your problem. Good luck.. hope this helps you.,..
Regards
Oct 12, 2008 | Hotpoint Dishwashers
The dishwasher is not emptying out the water. It needs to reset and finsh the last cycle. Hotpoint DWF 33
pump under bottom front panel might be clogged remove hose clap from pump,cleanout,also can use shop vac.,also remove lower spray arm then remove filter clean and replace,also check under sink make sure drain hose is not kinked,thanks-mike
May 27, 2008 | Dishwashers
Hotpoint dishwasher full of water after cycle complete
If the motor is running, the diverter solenoid valve is probably not functioning. It is attached to the pump. With the power off, take the solenoid apart and remove whatever is jamming it. Toothpicks are a favorite as are any large food particle. It may also be bad. Not the problem...you may have a defective timer or your outlet hose is clogged or kinked.
Feb 10, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Food particles on washed plates
Sometime food particles stick near the door gasket. First, try changing the DW soap brand.
Nov 16, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Neff 24 in. S5443X2 Built-in Dishwasher Logo
260 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
