Question about Mitsubishi WS48511 48" Rear Projection Television
Thing are turning YELLOW
Everthing on the screen that sould be white is turning yellow. Lettering and peoples faces all of the edges are turning yellow.
My 95 hitachi tv has yellow glare don't know how to ajust it or can you?
Posted on Nov 01, 2008
    President:
  • 4,402 Answers
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
http://www.partstore.com/GetModel.aspx?MfgName=Toshiba&BrandName=Toshiba&ModelNu...
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
Don not run the tv till you have it fix you will cause more damage!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Feb 12, 2008
We have Fedders model cnx 110 t3b. we are trying to change to new thermostat. Can you tell us what these wires go to... W1, X, Y2, Y1, G, Rc and Rh. They don't even have these on the new one, just a...
W1 IS HEAT ON WHITE WIRE X IS COMMON NOT USED Y2 IS SECOND STAGE COOLING ,NOT USED Y1 IS COOLING YELLOW WIRE TO AC G IS GREEN WIRE FOR FAN RC-RH GETS JUMPED AND CONNECTS RED WIRE.
RED WIRE AND WHITE WIRE TURNS HEAT ON RED AND YELLOW TURNS ON AC RED AND GREEN TURNS ON FAN AC MODE CONNECTS YELLOW RED GREEN
Apr 11, 2010 | Honeywell Electronic Programmable...
Both of my Alinco Hand held Dj-560 and Dj-580 will lose there memory when I turn the radio on the memory will be gone, and the battery is charged. Thank you, N7ERW
Go on ebay and finda br1225 replacement, with legs, my DJ580T has the one with one leg on top and one on the bottom with yellow plastic shrink-wrap around the edges of the battery. you have to take the radio to smithereens, ie take off bottom battery plate, take off all knobs - pull straight off, take off antenna, take out all 3 screws on body of radio, then carefully work back off and over the pots where you took off the knobs. there was no marking on my battery, but it is the button-looking thing with the yellow plastic around the edge. carefully de-solder old, put new in, then carefully reassemble radio. top edge has rubber seal, be careful it is in place, if twisted radio will not go back together. battery is about $5 shipped, on ebay. KJ4VSM, High Point, NC
Feb 23, 2010 | Radio Communications
Yellow edge to preview screen
hello. you may be involved in a recall. please read this http://www.nikonusa.com/Service-And-Support/Service-Advisories/COOLPIX-Service-Advisory.page
please rate my answer as very helpful thank you. joe
Feb 15, 2010 | Nikon Coolpix S203 Digital Camera
Our church has two Hitachi CPX 445 projectors, colors do not match, all settings are identical example, one projector will have bright white lettering while the other will display yellow lettering.
There is an appointed time for everything. And there is a time for every event under heaven-- there is a part of the projector called the polarizer.
The polarizer is just a light filter inside the unit, but the inside of the projector is VERY hot, so this part typically melts.
The most common symptom of a failing polarizer is color shift, typically yellow.
Nov 02, 2009 | Televison & Video
60" Phillips rear projector television has red, blue, yellow
you have a convergance problem with your set. How much it cost to fix dont know what area you live in so cant tell you. Could be around 300 to 400 dollars. That is in a shop or someone comeing out to your house to fix.
Mar 03, 2009 | Philips 9P6040C 60" Rear Projection...
Have yellow spot in center of screeen
it is actually a light engine problem, i have replaced probabily 50 of thease for that exact problem, it is a prity hard part to change yourself, and it costs about 400 dollars
Jan 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Yellowing screen off-center - not a convergence issue
You might want to try the optic lens adjustment screw on the side of each crt. Mark them before moving.
May 30, 2007 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi WS48511 48" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
