Question about Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer
Konica Minolta 7022- How to clean- Getting Dark Lines on Copies
I have a Konica Minolta 7022 and all my copies are coming out with dark lines. I have about 100,000 copies on it, so I don't think the drum needs replacing. I think it probably just needs to be cleaned. Is this something I can tackle myself? If so, what do I need t know? I have contacted a copier service that is going to charge me $200 for the cleaning- and that seems excessive to me.
Any advice you can give would be great.
  • 6 more comments
  • MReen Feb 12, 2008
    They are appearing both places with use of document feeder and glass.
    They Can't be rubbed off. They are grainy and sometimes they appear darker than other times. Sometimes it's just one line other times its several.
    What kind of money should I be looking to spend for the PM Kit?
    Thank you for all your help.
  • Anonymous Feb 23, 2009
    I have a line in the middle of all received faxes, tried to clean with cloth, problem not resolved.
  • brian c
    brian c May 11, 2010
    Sorry for all the questions, but this will aid in troubleshooting.
    These dark lines, do they appear "grainy" and can be rubbed off of the copies?
  • brian c
    Are the lines only appearing when using the document feeder, or also when using the glass?
  • Anonymous Mar 21, 2014
    horizontal blank portion on copies after replacing an old developer
  • 589 Answers
Beings as it is close to 100k, it is due for a PM (preventative maintenance) kit to be installed (this model has a 100k PM cycle), and also a web, corona wires, charge grid, and feed rollers (if worn) should be replaced at this point, and of course cleaned.
The drum and developer "should" last 200k (this can vary greatly).
$200 for a general cleaning on that series machine... that's entirely too much, and he will most likely tell you it's due for a PM. A competent technician would be able to install the kit, replace the above parts in under 2 hours easily.
I wish I could be of more help, but given that is almost at the end of its PM cycle, it could be anything.
Posted on Feb 12, 2008
  • brian c
    brian c Feb 12, 2008
    The PM kit for that machine is pretty basic, it's just fuser unit parts.
    The PM kit part number D26WEPM100 / 950-256 is $195
    Web part number 26NA53432 $29.95
    Grid part number 26NA25160 $49
    These prices are from www.precisionroller.com
    You can probably find them cheaper elsewhere (or even non-Konica parts), but I use these guys a lot, and they always have items in stock.
    The corona wires can vary in price, as do the feed rollers, depending if they bought them in bulk or not.
This can be bad drum cleaning blade.
Posted on Sep 30, 2008
Try this:
http://www.google.com.ph/url?sa=U&start=1&q=http://www.uninetimaging.com/newsletter/Konica_Minolta_1400W_DrumUnit_Reman_EngUK.pdf&ei=OrphSY3NEYXWswL537jsDQ&sig2=avm85Xgo1MwBJimn6cVSIw&usg=AFQjCNHpQupgieoECH5Ern4wAFH5eQUn8Q
Posted on Jan 05, 2009
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
C451 prints too dark
copies or prints to dark or both????
Mar 24, 2014 | Konica Minolta Office Equipment & Supplies
Dark streaks on copies
replace the the drum iff not that the the fuser
Jan 03, 2014 | Konica Minolta Minolta DI1610FP...
I an getting light copies on konica minolta bizhub 362 what is the adjustment to make copis dark
Normally light copy comes out when mirrors are dirty. Before any adjustment clean the slit glass and mirrors.
Dec 17, 2012 | Konica Minolta Bizhub 362 Copier
When photocopying the copies come out with dark lines across them
Clean or change the OPC drum cleaning blade,the drum.Clean the charge corona wire and grid,clean the optics,mirrors,transfer and separator corona wires.
Sep 13, 2011 | Minolta EP1030/1030F CS/PRO Copier
Dark horizontal lines appear across copies
This is usually caused by a dirty main charger grid, try cleaning it per the instructions in your operators guide. If you don't have the guide you may be able to download one from the Minolta Website at
http://kmbs.konicaminolta.us/content/support/supporthome.html
Sep 04, 2009 | Minolta Di151 All-In-One Laser Printer
Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer Logo
1,731 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
