Washing machine want spin. The pin not broke off on the lid. And I've tried all cycles.
  • 1 more comment
  • mom2tnjp Feb 20, 2008
    If the drive belt is broke how do you know?? I have my washer on it's side and am looking under it...can't figure out how to get the back off :-|
    But mine fills with water and empties it just won't spin,,,I think it is the belt but don't know where it is located or how to replace?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Mom2tnip: If you are going to post a problem, you need to mention the model number of the washer (located somwhere along the lid opening), and the brand name. This makes it much easier in diagnosing a problem for you. Some washers do not have drive belts and are direct driven by a transmission. Last of all, it's probably not recommended to remove the back panel.
    Warebear: Still never got any feedback on your intial washer symptoms. Have you found your problem? Do you still need assistnace? I will need a model number and brand name from you as well.
  • Jeff Rockwell
    Does the washer fill? Does it agitate? Is a "no-spin" the only symptom? The "pin" doesn't have to broken off the lid for the lid switch to be bad. The switches sometimes separate, come loose, or the contacts wear out. Post back and let me know.
    Problem Solver:
  • 10 Answers
Well if it just will not spin the drive belt might be broke
Posted on Feb 12, 2008
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Washer won't drain or enter spin cycle
SHOULD BE THE LID SWITCH... THERE IS TWO SWITCHS INSIDE, ONE THAT STOP THE MACHINE, AND ONE TO LOCK THE DOOR. YOU SHOULD SEE THERE IS TWO PAIRS OF WIRES THAT CONECT WITH THE LID SWITCH, ONE PAIR IN THE FRONT, AND ANOTHER PAIR IN THE RIGHT SIDE, THAT RIGHT SIDE IS THE PROBLEM, INSIDE THE LID SWITCH MUST BE BROKEN. TRY TO MOVE THE PLATED LOCKING PIN IN THE DIRECTION THAT LOCKS THE DOOR, AND IT MIGHT DRAIN AND SPIN. IF THAT THE PROBLEM, YOU SHOULD GET A NEW SWITCH (MODEL 134101800), AND YOURE DONE.
GOOD LUCK
MARIO
May 07, 2013 | GE Spacemaker Washer and Dryer Electric...
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
No spin cycle
Sounds like its the lid switch. Look on the cabinet where you shut the lid. Chances are the switch is broke.
Good Luck.
Jul 30, 2009 | Whirlpool Washing Machines
Whirlpool-spin cycle will not work
hi,
could be either the safety switch at the lid broke off or the plastic motor mount ujoint broke, they are both replaceable. have to study it. first open the lid and try and depress the safety switch, it should click. if it doesent thats it. if its the plastic motor part, the motor has to come off and a new plastic u joint goes in there, pretty easy fix, be careful and take time.
J
Jun 26, 2009 | Washing Machines
Opened it during spin cycle, machine kept running
if you open the lid, you will see a small pin on the lid proper, look where the lid seals when closed, you will see a small hole that that pin slides into. check to see if there is a blockage. if not. probably need to replace the switch that controls this.
Apr 25, 2009 | Washing Machines
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Washer won't complete spin cycle
Try pushing down lightly on the lid and see if the spin cycle starts back up. On mine, the same thing happened because the small plastic pin attached to the lid was just barely long enough to push the switch that tells the washer that the lid is closed. The spin cycle will only run when that switch is pushed, i.e., when the washer thinks the lid is closed.
Jan 06, 2018 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
443 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
