Question about HP Officejet J5780 All-In-One InkJet Printer
HP Officejet J5780 All-in-One
Labels do not print WYSIWYG. The vertical alignment shrinks progressively with the text on each line "moving" progressively towards the top of each label so that the last line of labels is outside the label print area.
    Genius:
  • 3,587 Answers
Your printing program needs a template, based on the label makers specs. That's usually what causes that, not the printer itself.
got backup?
Posted on Feb 12, 2008
HP Officejet J5780 all in one Alignment problem cartridge will still not align after I've gone through the alignment routine. Cartridges are genuine HP and fairly new
Usually the yellow is the culprit. Dab the cartridge on a paper towel and see if all colors make a spot or line. if any color is missing it will not pass alignment, and you need a new cartridge.
Dec 30, 2009 | HP Officejet J5780 All-In-One InkJet...
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
I have an HP Officejet Pro 7580. When printing in
Press "set up" button until number 6
Number 6 is "tools"
press OK
press forward arrow (to right of ok button)
No.2 is clean printhead
No.3 is align printer
No.4 is calibrate line feed
Mar 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet J5780 : copy's and scan's result : black page
Try to disconnect the power cable from the back of the unit and reconnect it after few secs. The alingment will start itself. Complete the alingment once.
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Prints every other line
Does it print every other line, or is it printing a blank line between your lines?
Jan 25, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer only printing top half of line
I switched my printer off at the mains and back on and this rectified the problem
Nov 17, 2008 | HP Officejet J5780 All-In-One InkJet...
I am going to give you the technical document which you need to follow inorder to resolve your issue. Just click the link below
CLICK HERE==>> SOLUTION ON VERTICAL LINES
Also, i want you to give me feedback on how useful is the document to you.
Thank you so much.
adonscott
HP TECH
Jun 26, 2008 | HP Officejet J5780 All-In-One InkJet...
Printer has started to misalign text, moving up past labels
Verify your paper settings match between the printer and PC. If a roller is dirty the paper might feed late.
Jun 17, 2008 | HP LaserJet 2420 Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
135 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
