Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Won't hardly spin
My washer washes It kinda goes in circles when it washes but when it gets 2 the spin cycle it won't hardly spin and it smells like burt rubber when it finishes with the spin cycle what could b wrong N when it washers does it suppose to go around or back n fourth? Please please help need to wash cloths badly lol
    Problem Solver:
  • 10 Answers
The back and fourth motion is normal. we have a ge and it does the same thing. for the slow spin and burt rubber smell the drive belt is more than likely streched, the fast fix is to replace the belt. HOPE IT WORKS FOR YOU!
Posted on Feb 12, 2008
My washer fills and drains but does not agitate and smells like burt rubber. what could the problem be
flip washer over and check the coupling between the motor and transmission of washer. if the coupling is shot it will not agitate or spin. if this model has a belt then check to see if it is broke!
Jan 14, 2010 | GE WBSE3120B Top Load Washer
Smokey smell starts when our washer goes into spin cycle
Smokey Smell = Prelude to a fire
Prelude to a fire= Put Safety thought processes into gear!
Dont use a machine that is both a wealth and a health hazard!
Oct 19, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Your washer has brake problems you need a qualified repair person
Apr 02, 2009 | Washing Machines
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Admiral washer lnc6160b71
If you mean the inner drum - remove the agitator, pull off the sofetener cup and remove the 15mm bolt down inside to remove agitator, then secure inner drum to center bearing.
If you mean the outer drum, check the holding down springs visually, remove the front panel by inserting a flat blade approx 4" from each side at the front to release clips, then remove 2 small bolts to remove front panel.
Also check and replace drive belt, tilt machine backwards to gain access underneath.
Jul 15, 2008 | Admiral AW22 Top Load Washer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
174 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
