Question about Samsung SCX-4521FG All-In-One Laser Printer
I need the Power Supply part number for my Samsung SCX 45521F AIO, Thanks!
    Sergeant:
  • Samsung Expert
  • 406 Answers
Dear sir,
Power supply you need you may get it from nearest service center {or directly get it fixed by them only}As I know the spare parts are not directly available from outlets.
Regards
Posted on Feb 12, 2008
Problem on my All-in-one
Replace all electrolytic capacitors on the secondary side of the power supply board. Or replace the power supply board.
Jan 04, 2012 | Samsung SCX-6322DN All-In-One Laser...
Samsung scx 4521f warming take too much time
take the back cover off. you will see in the power supply there is one capasetor which need replacement
Dec 05, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4826FN/XAA toner exhausted
You need to replace the toner cartridge with the following part number MLT-D209L or MLT-D209S or MLT-D2092L.
Take these numbers to your local cartridge shop and they will be able to supply them.
Regards GM
May 27, 2011 | Samsung SCX-4828FN All-In-One Laser...
Samsung SCX-6322DN power to display "system
Dear
Try to re assembly all harness terminated at main board, Test the machine on toner cart and drum cart opened. System not initialized, check the main board.
Thanks.
Apr 02, 2011 | Samsung SCX-6322DN All-In-One Laser...
I use Ubuntu 10.04 and I want to install my printer Samsung SCX-4623F. What do I have to do? Thank You. Eros.
Hi there and welcome to fixya,
What's the model code for your printer?
There are three options;
XAX, XAA, XBG
For a direct link to the XAA type, follow the link below:
http://www.samsung.com/us/support/downloads/SCX-4623F/XAA
otherwise, you'll need to select the correct model code on the drop down.
On the Driver tab. Download the driver file under LINUX.
Hope this helps.
levbit
Dec 25, 2010 | Samsung SCX4623F Laser All-in-One Printer
Samsung SCX-4521F Possibly lost its power? When
If it just make tick sounds, but does not power up and does not do its normal startup, it probally the power supply board on this printer has failed. This printer like most modern electrical appliances has a switching power supply. The ticking sound is the power supply trying to start, but it senses a fault and shuts down and tries to restart.
I had a similar problem with my printer, though it not the same model (CLX-3160) but the same manufacturer Samsung. I took mine appart and found that one of the capacitors on the power supply had failed. It was blown and the top of the capacitor popped open. I am not saying this is your problem but it would be the first thing I would check if you want to get this fixed. Otherwise, look for a new printer.
Hope this helps.
Jun 29, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521F Multifunction wont power on
Power supply on the printer is faulty. It might only be a fuse though, but you have to disasemble the printer to check the fuse.
Aug 04, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Cartridge Error Message
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
Feb 16, 2009 | Lexmark X7170 All-In-One InkJet Printer
Samsung SCX-4521FG All-In-One Laser Printer Logo
127 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
