Question about Whirlpool MH1150XMQ Microwave Oven
MH6150XHQ-1 Blows Circuit Breaker Randomly
See no trend as to when the breaker blows. Upon reset could be go for 2 days, or may pop 30 second or 1:30 into next heating session.
I just want to determine if its worth repairing, and if its safe. Neither seem logical based on age of unit (manufactured 11/2001).
Thanks for responses.
  • Whirlpool Master
  • 9,098 Answers
When it blows the breaker, as opposed to the internal fuse, quite often that's a defective door switch or door switch mount.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 27, 2008
  • 579 Answers
The problem is from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still having problems, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Feb 12, 2008
My maytag microwave blew the ciruit breaker a several times last night. I reset the circuit breaker each time. Then the last time, I reset the circuit breaker and the microwave did not get power back....
If there's no other appliance on that circuit, then please stop trying to use the microwave. You could be dealing with a dead short, and those sometimes leave people,,,DEAD!
I would be really cautious about trying to use it anymore without checking it first for a direct short.
You need to allow the circuit breaker more time to reset, flip to off and give it 2 minutes, then turn it back on. You should feel the distinctive click, as well as hear it if it's working properly.
Circuit breakers can go bad after repeated failures within a circuit.
The outlet could also be damaged now, but normally it's the circuit breaker getting too hot with repeated failures.
If there are a number of other items on the same circuit, then try the microwave in a plug that you know has no other items being used at the same time, preferably while wearing heavy duty leather insulating gloves to protect yourself from any possible shock. If the circuit breaker blows, you've got a possible electrical short within the microwave.
Mar 27, 2012 | Microwave Ovens
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
May 09, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Randomly blows circuit breaker while not running, only the clock is on.
Normally when the circuit breaker blows, it a bad door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
Dec 03, 2007 | GE JES1358 Microwave Oven
Microwave Trips Breaker and Blows Fuse when not in Use
Since the internal fuse blew, the problem has to be either a surge from the power source, or an intermittent or transient short at some point beyond the fuse. With the unit unplugged, I would first look at the varistor (surge absorber) on the control circuit board to see if it might have taken a transient. It may look charred, distorted, etc. Then I would look at the door interlock switches and mounts to see if the switches are clicking properly and if they are aligned and secure. The purpose of the monitor switch is to blow the fuse (and usually the breaker) if there is aan interlokc problem. Next would be a look at the condition of the wiring from the fuse holder all the way back to the power cord. Then just for good measure, I would test the power outlet. A toaster is a good high-current load to use. But I don't think the problem's in the wiring or breaker. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find the wiring diagram, helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 Be sure to use a proper ceramic appliance fuse that's meant for the job.
Mar 13, 2007 | Jenn-Air JMC7000 Microwave Oven
Jenn-air model jmc7000
Can someone tell me where i can find fuse for microwave convection/grill oven 5kv 700ma There is a other no on the fuse TUV5m41GF
Aug 29, 2006 | Jenn-Air JMC7000 Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
388 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
