Question about Philips Magnavox 51MP392H Rear Projection Television
56" Not sure of model # soory.My set just started to tick sound like back lower side picture and sound fine.But as soon as you turn on ticking starts.Do you know what this is coming from?? thanks john
    President:
  • 4,402 Answers
Power supply is in protection mode. it's a rely click.
Posted on Feb 12, 2008
Engine starts and stops ticking
Sounds like oil pressure problems to me. Check to make sure your oil level is correct. If the oil level is OK get the engine checked by a professional.
Mar 24, 2012 | Chevrolet S 10 Cars & Trucks
We just purchased a dynex stereo headset with microphone, we want to use the headset in a webinar course where we need to listen and speak within the seminar, we have a MAC book, 2 plugs (pink is mic...
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
you might have to get a portable usb sound card if you mean dont have a sound card installed
also
the headset should have 2 plugs one green one red they usually plug into the back of the computer with the speaker plug in the middle you could alternate these also make sure the microphone settings are correct
hope this helps
Apr 06, 2011 | Computers & Internet
Please provide me step by step instruction about the installation of a headset to my PC. My mouthpiece does not work due to installment problem but the speakers work well. Thank you. I look forward to...
hope this helps
don
Feb 19, 2011 | Computers & Internet
2005 Diesel F-350 turn over but will not start
check heating module, follow wires from heating plugs and you will come to it hope this helps?
Aug 27, 2009 | 2005 Ford F 350 Super Duty
Kawasaki Vulcan 1500 (not FI) funky sound after shut down
Hi, Yes it is an electric fuel pump and the ticking is the pump working. So if you hear the ticking your pump should be OK. After turning off the petcock and running the carbs dry the next time you turn it back on you should leave the kill switch on and turn the key on and wait till the ticking stops, turn the key off and back on and wait for the ticking to stop again. You should do this a couple of times to make sure the system fills. Normally you should always use your kill switch to turn off your engine. Also under normal conditions you will not hear the ticking as it only ticks a couple of times to fill the system once it is full. Good Luck to you, This should Fixya!
Mar 24, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
Ice maker "ticking" sound?
Mine started doing the same thing. The problem with mine was that the part that spins around to eject the ice is hung up... first, it was trapping an ice cube in it... I cleared the cube and it stopped making noise for a while, then a cube hung up again. Now I found that one of the 'teeth,' all the way to the right, was stuck under the housing... the part is bent, and needs to be replaced.
Check the part that spins to make sure nothing is stuck. Service is expected in home soon (I hope).
Jul 05, 2008 | LG LRFD25850 French Door Refrigerator
Samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Feb 12, 2008 | Samsung DLP HL-P5663W 56" TV
No picture, then no picture and no sound
if your could hear a slight ticking (tick-tick tick) or whining then some electronic component might have been damaged (shorted). if you have no experience repairing electronic equipments then i suggest you to send your TV to a service station!
Nov 14, 2007 | Toshiba 27AF42 27" TV
No pic no sound just ticking
This set normally has problems in the horizontal and high voltage circuit. The horizontal output will short out and I often change the high voltage transformer. The high voltage splitter is another one of the usual suspects. Since it's ticking at plug in, then, I would look at the secondary of the high voltage transformer or the regulator circuit. Checking the the horizontal output first for a short and if ok, checking the B+ voltage on the collector would be my next step. That should give a good thought as which direction to go. Hope this helps.
Apr 01, 2007 | RCA P56812BL 56" Rear Projection...
TV starts but Does Not show picture or no sound
The Tic Tic sound is a result of the high voltage shutdown circuit. Thats what the circuit does if theres a short in the Highvoltage sweep. like maybe a shorted horizontal output transistor??. The only way to really tell is go in and measure the start up voltage and if the Hivoltage comes up and shuts down its a fault in the shutdown or Hhv regulation circuit . if it dosent come up at all then the faults in the Horizontal sweep circuit . Hope this explains a bit? good luck
Jun 03, 2006 | Philips 28PW6006 28" TV
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
