Question about Sharp EL-1197P Calculator
Sharp el-1197p3 i hit reset on it and now it won't turn on. what can i do
  • Anonymous Dec 20, 2008
    can't turn on
  • 682 Answers
Push and release reset button many time while you apply dry contact cleaner on the button- remove the power and return it twice.
Posted on Mar 10, 2008
All my answers come in decimals on my sharp el-531x and i want to turn it to normal
Press the SETUP key, press 0 for FSE, press the down arrow key, and choose 3 for norm 1. The calculator should return to normal. If all else fails, there is a reset button on the back.
Dec 08, 2013 | Sharp el-531x scientific calculator
How to change the tax rate on a Sharp EL-1801C calculator
Enter the desired number for the tax rate... followed by hitting the "STR" button... followed by hitting the "Tax+" button. Here is a link to the manual for the Sharp EL-1801C. http://bit.ly/lf3edL
Jun 19, 2011 | Office Equipment & Supplies
Need manual
You probably won't be able to find a free one, but downloading online manuals only cost a few bucks. Here is a link to one website that is selling it. http://www.devicemanuals.com/manual/Sharp-Calculator-EL-2630PII-Operation-Manual-TWpVMk1EST.html Best of luck to you.
May 03, 2011 | Sharp EL-2630PII Calculator
I have a Sharp EL-531W.All keys work except for sin cos tan hyp.
No solution, but I have the exact same problem with a Sharp EL-531W calculator. Doesn't matter whether mode is degrees, radians, etc., and resetting with button in back has no effect.
Feb 26, 2010 | Sharp EL-501WBBL Calculator
Hi I have a EL-1197PIII. I have moved it from my
The "E" is an error indication. If you divide a number by zero that would cause it. But a reset should clear it. Also dead backup battery will cause it.
FIRST replace the backup battery in the unit. There is a small panel on the bottom to access it.
Then do the reset. There is a "poke hole" to reset it that should be marked. Refer to your manual which is also available for free download online.
Nov 05, 2009 | Sharp EL-1197P Calculator
Sharp EL 531w . the calculator doesn't turn on.
Press the reset button on the back. If that does not work, batteries may be dead. Once you replace them press [ON/C].
Hope it helps.
Apr 15, 2009 | Sharp EL-531VB Calculator
Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Mar 26, 2008 | Sharp EL-2630P Calculator
Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Jan 20, 2008 | Sharp EL-1701C Calculator
Clock & Date
You can download the manual from the link below: http://www.sharpusa.com/files/cal_man_EL1197PIII.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Sharp EL-1197P Calculator
Sharp EL-1197P Calculator Logo
406 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
