Question about Intel Motherboard
New motherboard will not boot
I have built 7 computers previously by purchasing components, assembling, installing OS, etc. I just recently bought an Intel D945GCPE motherboard, PS, CPU (Core 2 Duo 4500 2.2 GHz) and 1 GB DDR2 RAM. I am reusing a 160 GB hard drive and have a new Lite-On DVD ROM, both of which have SATA interfaces. No matter what I do, I cannot get the system to boot. The BIOS comes up fine and displays on the monitor. It shows correct info detected on CPU, RAM, DVD, and hard drive. However, when I allow it past the settings screen, the lights on the DVD and hard drive continue to come on in an alternating fashion for about 3 seconds each in a continuous loop. Nothing else shows on the display. No codes are shown nor are any beeps generated by the motherboard to indicate an error condition. I cannot get the DVD drawer to open to even insert my OS disc.
I have never had a problem with an assembled system before and this one has me stumped. I have triple-checked PS, SATA, and case connections and everything appears correct. I would appreciate any advice or insight.
  • 24 Answers
It appears that you are aware of Motherboard jumpers.
1. Reset BIOS settings by CMOS Clear jumper ( Location of jumber is given on the sticker / manual of motherboard )
2. Try updating BIOS of your motherboard from the following link :
3. Plug only Optical Driver / Hard disk at a time and check.
4. Contact your vendor and get the motherboard replaced.
Posted on Feb 12, 2008
Please throw it away
Posted on Feb 13, 2008
Should I remove Windows Vista on my Compaq Presario Laptop? It is installed as OE but I amm told Microsoft does not support it anymore
For the past few upgrade cycles I have upgraded by purchasing the best value new computers with the OS installed. I connect the old computers to the new via a home network. The newest has Win-7 and is much faster, however, the learning curve is steep getting all the old stuff to work. So for some stuff I still rely on the older machine. This has given me the best results.I still use Vista and XP, but if you feel compelled to upgrade do to security reason I would follow the following outline.
  1. Back up on an external USB drive all important documents. You must do this if not Murphy's rules will apply and it can be a train wreck!!
  2. Down load Acronis from Western Digital website. Make a Boot disk.
  3. Create a clone copy of your master C:/ drive on an external USB drive.
  4. Purchase a same or larger internal PC master C: drive "It must be a Western Digital for the free version of Acronis to work"
  5. Replace current drive with new.
  6. Using Acronis boot disk boot up and connect USB drive
  7. Clone new drive from USB with vista OS using the Acronis boot disk and confirm all is well
  8. You now have a way to go back. Your original drive still has the Vista OS with all your Junk and the new drive should have the same.
  9. Using the new drive go to the Microsoft website and go for OS seven. Keep your clone copy of the vista OS on the USB drive in case the seven blows-up during install.
  10. Retain the original C: drive with the vista OS in case you get into difficulty with the new drive.(mark the drive with date etc)
I have successfully done this for computers and keep a drive loaded with a known good OS for the day it all goes bad.
Sync-toy is the backup program that I use to keep everything up to date.
Hope this helps?
Mar 09, 2016 | Compaq Presario C700 Series Laptop...
Upgraded motherboard and windows 7 in restore during startup
If you put in a hard drive that already had an OS on it and such, it won't work since the new computer has different parts from the last. You will have to buy Windows 7, or obtain windows through some method of your choice and do a clean install. Sorry buddy.
Feb 21, 2013 | MSI B75A-G43 Motherboard
MSI P965 Pt Continually re-boots on start-up
You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
Dec 31, 2011 | MSI P965 Platinum Motherboard
Could you give me instruction on how to install win 7 in laptop,
  • Obtain a windows 7 dvd and serial, this is easiest if you actually buy it.
  • Backup any and all information you want to keep on the laptop
  • Put the DVD into the laptop and restart your computer.
  • If prompted select boot from CD.
  • If your previous operating system loads, restart the computer, go into the bios settings and change the boot order to CD then HDD
  • Restart again, this time it should boot from CD.
  • Reformat the entirety of the HDD space into NTFS and select the reformatted space as the place to install windows 7, if offered, choose 64bit (x64).
  • Let it do its job, this may take quite some time.
  • Voila you have a new OS
Jul 17, 2011 | Computers & Internet
I just upgrade to Win 7. Now everytime when powering up the machine, there are two boot options like this: Previous Windows Operation System Windows 7 (with Windows 7 highlighted) Of course I...
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer.
When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
Jun 11, 2011 | Microsoft Windows 7 Ultimate for PC
How can i update the bios on my Hp g60t-200 laptop?
May 28, 2011 | Computers & Internet
How to install windows 7 operating system
To Install the Windows 7 Operating System (Win 7 OS):
Instructions for a "Clean/New Windows 7 Installation:
1) Insert your Genuine Windows 7 System Disc (Retail or OEM System Installation Disc).
2) Close down all programs and restart your computer.
3) As soon as the computer restarts, you should see a prompt that says something like this: "Press any key to boot from cd/dvd"
....So press any key!... This will boot to the installation disc and prepare for installation or repair (we are going to be installing windows, so ignore the repair options you see on the screen).
*If you don't press a key in time, you will see that the computer will attempt to boot from the hard disc drive instead... if that happens, restart the computer and press a key when prompted.
4) Depending on your particular Windows Version, you will see a prompt that says something about "Do you accept the license terms?" Click "Yes" or "I accept", etc.. and continue on...
5) Choos Custom or Advanced Settings (the other option is for an upgrade..)
6)Select the desired hard disc drive, (HDD aka Hard Drive), Select "Drive Options", and follow the onscreen instructions "Delete the partitions" (Do not Leave another windows installation on the same hard disc drive, unless you are experienced and know how to "dual-boot" properly!) Delete the Partitions.
7) Now choose to install windows (be sure to select the newly deleted empty (unformatted) partition. Windows 7 will automatically format the drive for you and will begin to install windows 7. Follow the onscreen instructions and within a half an hour or less (depending on your hardware) you will be finished, just be sure not to leave the computer unattended while performing a windows installation, since it requires your input quite often to proceed.
That's pretty much all there is to it!.. if you have any more trouble...
Google it or Bing it.... Search Engines are awesome!.... Enjoy!
*NOTE- If your windows 7 disc is a "Upgrade" disc, then you must perform an upgrade while running your previous/older windows version, since Windos Upgrade Discs aren't bootable, they simply patch the older version, replace system files, etc... to transform the previous windows installation into the target/newer version. If you want to perform a clean install, be sure you own a Windows 7 Installation / System Startup Disc.
Jul 06, 2010 | Intel Motherboard
Error loading operating system
You have to re-install your Operating System. You have significantly changed the controllers of the mainboard (from ASUS to GIGABYTE) and therefore all of the device drivers and controllers etc that are loaded into your OS are for the ASUS board.
You can get away with no OS reinstall only if you change the same brand of mainbaord, even then its not always 100% compatible.
Mar 28, 2009 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
I can't boot from CD. Can't boot previously installed OS
Hi, Make sure that you set the POST first boot to CD. If the disk is a bootable disc, you should be able to boot from the CD. If you have any questions, please feel free to contact me ASAP. Thanks, Mike
Nov 02, 2008 | Biostar K8M800 Micro AM2 Motherboard
I bought used d600 and need to format it
you can do the following.
D drive can be formatted from windows itself. open my computer. right click and click format and follow instructions.
But C cannot be formatted from windows as it contains files that would be in use.To format C insert the windows(OS) CD and restart. change boot option. this can be done by pressing F4 or F8 while the system starts. now cahnge boot device to cd. now follow the instructions to load the OS(windows) and install it in C. Select quick format or format and you are done. All previous data and the OS would be deleted and the drive would be formatted and the new OS would be installed. If You want to keep your previous files, select keep files system intact while the procedure is being run.
Dec 30, 2007 | Dell (04U621) for Latitude D600, Inspiron...
Intel Motherboard Logo
121 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
