Question about Canon PC-940 Black and White Copier
PC940 dark lines across the middle of the page
I have a black streak about an inch or so across every page I copy. Tried a new cartridge. Can I assume there's something somewhere that I havent cleaned? Any clues would be appreicated, especially since the nearest service center is a 5 hour round trip drive from here.
  • 1 more comment
  • mrdrip Mar 02, 2008
    I finally got around to working on the machine.
    I stopped the machine midway making a copy. The line is on the copy half.
    I assume it's the optics? How do I go about repairing that problem?
    thanks,
    Darrell
  • mrdrip Mar 09, 2008
    Is that the same as the toner cartridge? If it is, I replaced the generic with a canon cartridge a few months ago. Problem never changed.
  • Tannertat Sep 20, 2008
    Have a 3" wide smudge line down the middle [lengthwise] of all copies using auto contrast. If I use the manual contrast I can remove the smudge but the text is significantly lighter. Have worked with better copiers and this problem can be resolved normally be adjusting the auto contrast. This machine doesn't have this function - unless it's in the service manual [which I don't have].
  • 168 Answers
Either the Fuser/Heating unit is bad, or the optics are dirty.
What you can try to do to narrow it down, is to make a copy but.. STOP the machine in mid process by turning the power off. This will create a paper jam in the machine. If timed properly, your copy should be 1/2 way through the machine with some image on it. (Make sure that you are trying to copy something on the glass). The copy is not FUSED, so the toner will wipe off so be careful not to rub the page against your clothes/sleeve. IF the black line is on the page at this point, the problem is not in the fuser but probably in the fiber optics. If the problem is in the optics and will need to be cleaned. If the black line is NOT on the page at this point, then the fuser unit is bad and needs to be replaced.
Let me know how the copy comes out when you stop the machine in midway and I can see if i can give you any more suggestions.
Good luck.
Mac
Posted on Feb 13, 2008
  • Mac Gyver Mar 04, 2008
    It still could be the image cartridge. This is usually a common problem when you start having copy quality problems.
    How old is the image cartridge?
Dark streak on paper
you need to clean the rollers. consult the manual about cleaning the copier. if you don't have a manual, then get some methyl alcohol (any alcohol that evaporates completely will do). use a lint free cloth to rub a small amount of alcohol on all roller surfaces (accessible via pull-down compartments on front and back, usually).
Nov 29, 2011 | Canon PC-921 Black and White Copier
I have dark streaks with all print-outs on a Samsung ML-2510. It goes away on a new cartridge.
This is a common problem with a close-to-empty cart.
A new cartridge will have even toner, and will distribute it evenly to the page.
An older toner will start to streak and line onto the page.
Another issue could be the fuser... some of the new printers have a fuser built into the cart unit... so that when you replace the cartridge it replaces the fuser as well.
A fuser can become dirty and thus not distribute toner evenly across the page.
Cheers!
Feb 23, 2011 | Samsung ML-2510 Laser Printer
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Thank You for using Fixya.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
Dark black streak down the middle of the page
sounds like your cartridge is leaking. I'd try replacing the cartridge
Apr 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Dark streaks on copies from Xerox XC356 copier. Streaks were light at first; changed to a new toner cartridge and streaks are same size/same place on the page -- but now darker. There are three streaks,...
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
Mar 04, 2009 | Xerox XC356 Copier
Pc940 faded centre
Have you replaced the drum cartridge yet? Or did you and this what you are getting. If the old drum was working ok, but dark. You may have a defective drum unit.
Feb 06, 2009 | Canon PC-940 Black and White Copier
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Printout blank
this is problem with cartigdes only just installed new one and see.
Oct 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
Canon PC-940 Black and White Copier Logo
577 people viewed this question
old marine
old marine
