Question about Philips Magnavox 27MS343S 27" TV
Magnavox 15 inch lcd hdtv
I just purchased a refurbished 15 inch lcd and it came without power cord, manual or remote..I'm not really tech savvy..what cord should i get? Where do I connect it?..also..will any universal remote work with the set?
    Sergeant:
  • 319 Answers
The typical power cord is usually the same kind that is plugged into your monitor right in front of you. Buy another one of those. A universal remote should work (not promising anything)
Posted on Feb 12, 2008
I have a 42" Vizio
Your power supply is dead.
Power supplies can be purchased online for a couple hundred bucks, and replacement is fairly simple and requires only a screwdriver.
For those less tech-savvy, you may want to start saving for a new TV.
Jun 07, 2011 | Vizio 42 in. LCD TV
Television won't turn on or off with remote or manually.
The tv have a power supply board problems.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com to buy a whole new refurbish power supply board for the replacement,will solved this problems.
Jun 06, 2011 | Philips 42PFL5332D 42 in. LCD Television
Tv button on remote does not power on my tv neither does comcast remote
U try to power on the tv by pushing manual power button on the tv itself?Yes,tv still have no power than ur tv have power supply board problems,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.If it the remote problems call ur cable company for the cable remote replacement.Try website like Remotes.com to buy the tv original remote for the replacement.
Apr 13, 2011 | Sony KDL-37L5000 37 in. LCD TV
Samsung LCD 650 tv . Problem is that when using remote to turn on is appears to cycle on and off repeatedly making that annoying samsung noise. Nothing appears on screen. Unplug it and wait a few minutes,...
The tv power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Televison & Video
My samsung t.v. 52 inches will not come on it
My tv is brand new samsung 32 inches lcd. I accidently press power button several times and now i dont see any red dot. when I use my remote control, i see red dot but thats all
Jun 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
Where can I get a power cord for niko 26 inch?
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
Feb 06, 2009 | Niko OTP-2613W 26 in. LCD Television
The TV will not power on with remote or manual button
Have you had any major power outages in the days leading up to this issue? It could be a power source, cable or outlet. Try different outlets if you can and see the tv responds.
Best of luck,
Al
Apr 18, 2017 | Cyberhome CH-LCTV 150 15 in. LCD...
No power
Obviously, first check for AC pwr at the outlet, plus check the power cord connection at the set itself. If you have an AC voltmeter, use it to confirm that power is actually getting to the set.
Have you tried both power buttons on the remote AND on the set itself?
If all is well in these checks, then the set likely has an internal problem- perhaps just a fuse, but usually fuse failure is caused by other circuitry failure. If the latter is the case, then services of a tech-savvy are necessary- costs probably $100 plus.
Jul 07, 2008 | Protron PLTV-32 Television
HP 15 inch lcd monitor
This sounds like you have a problem in your power supply. The capacitors in the power supply "clean" up the voltage and provide you with a steady power source. When the capacitors go bad you can be left with either a power deficit of a power surplus which could cause the problems that you are experiencing. Capacitors are pretty hard working devices that are much like batteries but charge and discharge really fast. Capacitors work really hard in a power supply and its not uncommon when they fail. Unfortunately the only thing you can do here is either purchase a new power board or if you feel brave, look at the caps on your power board and swap them out with new ones. They're pretty cheap and you might learn something.
Oct 02, 2007 | HP vs15 15"LCD Flat Panel Monitor
Philips Magnavox 27MS343S 27" TV Logo
185 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
