Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
Kitchenaid Dishwasher Control Panel lights - some don't light up
Need help with Control Panel lights...some work, others don't. Trying to start wash, and when you press the Normal wash, it doesn't light up. The cancel light keeps coming on when "start" is pressed.
It seems as thought the "touch" sensors are bad..any suggestions??
cycle stops - no lights - press cancel drain its led blinks. -press any other key the rinse only light blinks.
  • fixallofit Feb 12, 2008
    before receiving your response i arrived at the same cause - with the panel loose evrytime the cycle stopped and led's were blinking i touched the ribbon cable and the led's and washer acted normal. i will try the pencil eraser fix but it also could be a cold solder joint on the oin connector itself. the ribbon is terminated in a connector with female pins that mate to a male pin connector on board i will let u know.
  • Anonymous Mar 16, 2014
    water will not drain, control panel does not respond
    President:
  • 1,314 Answers
About the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Posted on Feb 12, 2008
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
IrishDruid
  • 2712 Answers
SOURCE: ////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Posted on Nov 26, 2008
  • 3 Answers
SOURCE: My normal cycle and cancel button lights are
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Posted on Apr 27, 2009
  • 56 Answers
SOURCE: the light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
Posted on May 31, 2009
SOURCE: Kitchenaid dishwasher KUDPO2FRSS normal and cancel
Where is the filter on the Kithchenaid KUDPO2FR$$4 Dishwasher ?
Posted on Jun 05, 2011
Control panel stopped working, no lights
The most common problem on washing machines and dishwasher is failure of the electronics, usually the circuit board. As you have already had a problem (sanitize cycle) I am afraid it sounds like you need to call an engineer. Replacing the electronics will be expensive, but it may be loose connections only. :(
Jan 11, 2014 | KitchenAid 24 in. KUDS02FRSS Stainless...
RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
I want to know what was the exact maker/model, part# of your unit
Thanks
Jun 01, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Dishwasher won't start KUDIO1ILBS
How old is this dishwasher that you are using? Is this under warranty
Apr 24, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Model KUDS30FXSS1 Kitchenaid dishwasher control panel stopped working at the end of a cycle.
I had a similar problem: unresponsive buttons, then the 1 hour wash button led was on but the other buttons weren't working at all.
I power off for more than 30 seconds and after that everything return to normal.
Thank you for the hint!
Nov 03, 2012 | KitchenAid Dishwashers
On kitchen aid dishwasher, control lock is blinking and preventing the use of any other execute buttons. Can't start a wash .
Which model KitchenAid dishwasher do you have? On some models, the Control Lock can be toggled on/off by holding the Energy Saver Dry touch pad for at least 4 seconds or until the Control Lock light turns on or off.
On another model, the touch pad to press and hold is the 4 Hour Delay button. (On that model, you press and hold for 3+ seconds.) There is often a very tiny label below or on the touchpad indicating which key controls the Control Lock.
If you haven't held the button for long enough, pressing the other touch pads will lead to the Control Lock light blinking 3 times if the Control Lock is active.
If the press and hold method still doesn't work after several attempts, then you may have a problem with the control panel. The dishwasher may need repair.
I hope this helps. Please add a comment with the model number so that I can check if a different touch pad key is the correct one for the Control Lock.
(the Control Lock feature keeps the dishwasher settings from being changed accidently or the unit started when it isn't needed. This can stop a child from resetting the dishwasher or the unit being started while you clean it.)
Oct 15, 2012 | Dishwashers
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Kitchenaid kud101tj "cancel drain" light and "Rinse Only" lights are falhing and DW won't start???
Don't know if this will help, but when I had problems with my control panel (lights blinked and nothing worked) I fixed it by disconnecting the power completly from the dishwasher at the fuse box. Leave it off 10 or 15 minutes and then repower. That reset mine and it worked again...has happened several times and each time I could fix it by cutting the power. If that doesn't work, you may need a new control panel.
Sep 11, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher won't work
i think they been charging you for the control panel and replacing the fuse there is a fuse in the control panel go to appliance parts store and tell them you need control panel fuse for your model get two or three then remove the panel and replace the fuse
Sep 07, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Jan 13, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
1,031 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
