CD PLAYER NOT WORKING
PURE LEGATO CD PLAYER DOESN'T WORK ,AFTER CLOSING DRAWER WITH CD IN IT IT SAYS ITS READING CD AND DOES NOTHING ELSE
  • Anonymous Nov 30, 2008
    player side wont read displays disc error and insert disc
    Sergeant:
  • 319 Answers
Laser lens broket..replace entire cd player by exchanging a $20 bill at a local merchant.
Posted on Feb 12, 2008
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
Whilst the cd drawer was in the open position I caught it with my knee leaving the drawer on an angle. When I press the close button nothing happens and any attempt to close manually is met with...
drawer is out of alignment...some players have timing marks to align the gears(similar to engines)...but without a service manual..it may be complicated...you can try to realign the drawer...there is a limit switch that tell the player when the drawer is fully open and one that tells the player when it is fully closed....a good way to try to realign is to move the drawer one tooth at a time and trying it..until it lines up
May 26, 2011 | Marantz PMD320 CD Player
The CD player in my Pure Legato 2 system won;t register CDs, the last few times I listened to CDs they skipped a bit, now it won't play them at all, it just reads 'no CD'.
I have fixed this problem in 2 Legatos. But don't attempt this if you have no experience with electrical equipment.
You need to open the case (4 screws deeply recessed in the back panel, 3 screws securing the speaker terminals and the phono socket block, and the nut and plastic washer holding the aerial socket. Gently ease the rear panel back enough to access the rear of the CD mechanism. Under the CD laser assembly carriage, there is a small trim pot (with a yellow cross-head adjuster screw). I found a small anticlockwise adjustment got the CD player working again. (I assume this trimmer increases the gain of the optical sensor amp.) Secure the rear panel before powering on again to test. It may require a little trial and error to recover the full functionality of the CD.
Good luck.
Feb 09, 2010 | Audio Players & Recorders
A cd is stuck in 5 cd player. Drawer won't close. (Sony) When drawer did open/close, it just started making a noise - maybe belt wearing out.
Without knowing the model number, this is pure speculation:
There are some Sony units that can easily get "out of time" in the loading mechanism. This can be caused by a broken trace in a ribbon cable or a defective sensor. Some models can get out of alignment or timing if you push the drawer rather than pushing the close button. Please update this with the model number, and I should be able to give you more details.
Thanks,
Dan
Oct 01, 2009 | Sony Audio Players & Recorders
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Rotel cd player Rotel 1070 cd player
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
Mar 03, 2008 | Audio Players & Recorders
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
624 people viewed this question
 Grubhead
Grubhead
