Question about Digidesign Mbox 2 Barebone
All the lights are on on my Mbox. it wont be recognized by pro tools. help!!
  • dirttdurk Aug 19, 2008
    Dirtt/Durk Da Texaz Boy
    Had Lighting glitch surge 3 or 4 time's ,it fried my power uint on my desk top got it fixed.
    But when i hit protool's short cut>>>>>>>>Bule Screen Hardware not installed right/ok so i reloaded every thing>>>>NOW It Say's No Quick Time 6.5/ I Have 2 Reinstall it,But I Never Ran my CPU Wit Ouick Time???
I did all that but i cant get any sound out of my reason4 and my protools wont open anymore .what can it be? is it fried ? should i buy another box?
Posted on Jun 27, 2008
    Sergeant:
  • 243 Answers
Un plug it uninstall the mbox and all the asio drivers. update protools. then reinstall the mbox and all the asio drivers you should be fine.
Posted on Jun 13, 2008
When i plug in my mbox mini 3 the blue light come on, but when i try to lauch pro tools it says that hardware is not recognize. When look at the mbox mini control panel, it says that it is not connected...
Assuming you are on a Windows system, go to Control panel/Sounds and devices/ and check that the Mbox2 appears as the default in the Audio and also Voice tabs/panes while unit is connected. If it is not, select it in each... if it is not in the list offered, then the drivers have not been installed for the Mbox.
Aug 24, 2011 | Digidesign Mbox 2 Mini Workstation
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
Installed pro tools 8 on macbook pro. when i try to open pro tools it says the hardware cannot be found. mbox2 is connected but the usb light is not on.
I had this problem as well... If this is a 2011 macbook pro you have os 10.6.7 which is not supported by avid at this time. We actually need to down grade to 10.6.6. You installation cd with your macbook pro is 10.6.6, so you'll need to install that, then go to the avid website and download pro tool le 8.0.5. Everything should work fine just don't upgrade to 10.6.7 until it has been approved by avid. If you need detailed steps look at the avid forum for pro tools. Step to uninstalling and installing the os can be found on youtube.com... Do not have your mbox plugged in when you install pro tools. I hope this helps!!!
Mar 29, 2011 | Digidesign Mbox 2 Barebone
Pt wont see my mbox
need driver for ct4670 sb!tnx!
Oct 09, 2009 | Digidesign Mbox External Sound System
MBox 1 Compatibility with new Macbook Pro Unibody and OSX 10.5.6?
unfortunately any pro tools application below version 7.4.2 is not compatible with leopard and I don't think you can use mbox 1 with the universal mac I may be wrong but I wanna say I tried a while back and even garageband wouldn't find it anymore but you can check for sure by going to the applications folder then open the utilities folder in there is an application called "Audio Midi Setup" and you can select the mbox in there if you see it but if not there is no patch or driver that I know of to get it working unless you upgrade pro tools which if you do upgrade I suggest getting mbox 2 and getting LE with it
Mar 12, 2009 | Digidesign Mbox External Sound System
Macbook pro does not detect digi 002 rack
yeah i have an intel imac and had the same problem. I upgraded to pt le 7.4 and now pro tools recognizes the 002 rack and it works fine, but still the core audio manager does not recognize the hardware. It says in "use" when I first turn on the 002 rack, then it says not connected after about 20 seconds. I don't think this really matters though because I have beeen able to do everything fine without having the core audio managr recognizing the 002 rack. I hope that helps
Dec 04, 2008 | Computers & Internet
Mbox 2 and new macbook pro
my Mbox isnt being found by my mac. when i try and install protools it tells me the mbox carnt be found. i have tried different usb cables ect but nothing seems to work.
Jul 22, 2008 | Digidesign Mbox 2 Barebone
Digidesign Mbox  2 Barebone Logo
1,337 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
