Question about Maytag Atlantis MAV7260B Top Load Washer
Maytag washer Washing machine will fill up, but then won't do anything else. Even if I turn the knob manually, nothing else will happen.
    Problem Solver:
  • 10 Answers
The timer might be broke, well let me explain more the prongs on the back of the timer might not be making contact so the washer will not start.
Posted on Feb 12, 2008
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Maytag top loader will fill but won't do anything else.
Well everything has a lid switch on it (Gee thanks Ralph Nader).
Yours is hidden at the 12 oclock position of the lid switch. You must pop the top to get to the lidswitch. I have a single belt maytag service manual HERE on my blog
Jun 12, 2012 | Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
My Maytag Washer Model A606 just quit working. No
The small fuse will prevent water from filling if it is blown. .3 amp
Jun 10, 2009 | Washing Machines
Knob is turning through cycles but nothing is hapening
check to see if your lid switch is broken also be sure to have your inlet water at least hooked up to cold in the back because yore machine only advances in cold water rinse if your cold water from the house is running to the washers side hot the timer will not advance to the next setting and finnaly youre drainhose needs to be at least as high as your washers water line hope this helps bakersfield maytag repairman
Dec 18, 2008 | Washing Machines
Open Questions:
Maytag Atlantis MAV7260B Top Load Washer Logo
113 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
