Question about Gemini XL-500 Turntable
Cable conector with ground from turntable to receveir
I miis plce my cable conector from my xl-600 turtable
    Sergeant:
  • 319 Answers
Aaaaaaaaand...........what's your point?
Posted on Feb 12, 2008
Loud buzz from deck, seems to be coming from RCA cable
It seems that is bad grounding of the gear, check i everything is conected to ground. I can also be the quality of the cable, Bad cables can produce a lot of noise, try using other cables.
Apr 07, 2015 | Technics SL-1210 Turntable
Do you need a ground wire between the turntable and receiver? if so, where to attach to the turntable?
Well read your guide, instead of easy ask things, a phono output has a ground wire, and if your tt has a line output, just use a cd or aux input. If your amp doest have a line input and your turtable only has a phone and ground output, you need to buy first a phono amplifier and connect that output to a line input on onee of your amplfier.... Jst buy a cheao one fron project for 100 euro
Sep 10, 2014 | Audio Players & Recorders
JVC - Turntable - QL-F4 - Noise coming from the motor ?
You don't say whether your turtable is grounded by a separate wire but in some cases grounding is necessary to eliminate hum.
Feb 25, 2014 | JVC Audio Players & Recorders
The turntable is playing crooked. how can i re align it?
check the rubber bushing that support the turtable fom the bottom. if they are worn or poped off replace them. if it is the turntable itself and not the whole turntable assembly check the bushings that the turtable spins on for side to side play. if they are worn replace them.
Dec 23, 2010 | Crosley 4-in-1 Entertainer CD Shelf System
How can i connect my Gemini Turntable which has a ground cable connection to a device that does not have a ground cable connection?
Hi, slip the ground cable in the side of the rca connection to the device without earth point.It makes no difference if it goes in the left or right jacks. styluscity@gmail.com
Sep 06, 2010 | Gemini XL-500 Turntable
How can i connect a gemini turn table with a ground cable to a input that dont have the ground connection gchristinam@yahoo.com
See if you can attach the ground wire to a point on the chassis of the device you are connecting it to.
TurnTable left channel no signal
Somewhere in the jack or the plug you have a wire broken. You will just have to look for it. If you have a volt ohm meter, this will aid you in finding the broken conductor. When you find the bad connection, you will probably have to solder it back together.
Dec 29, 2009 | Stanton STR8-80 Turntable
Have a Sansui compu edit p-m70 turtable. I turn
Lift off the turntable mat and the platter. Near the tone-arm, remove two screws holding down a panel and then inspect the tonearm belt. They wear out and stretch out and this could be the problem. Replacement is easy and does not require any special tools or further dissasembly.
Lock light indicates that turntable platter speed has reached correct speed.
Aug 21, 2009 | Sansui Audio Players & Recorders
I have a Sharp VZ 2500. The drive belt lies in pieces at the bottom of the player, so I can assume it needs replacing. I've bought the belt, but have no idea where it goes. Can you help?
you have to remove the front cover first. then detach the two wire connectors attached to the turntable circutry. Also detach the pushbutton pannel. remove the two screws that fix the top plastic cover inside the turtable housing. then the two big screws that fix the turntable to the main body will be visible. remove them and you can detach the turtable unit out. then remove the circuit board behind the turntable. you can then put the belt between the big disc and the motor pulley on the corner. Good luck
Aug 03, 2008 | Sharp Audio Players & Recorders
Gemini XL-500 Turntable Logo
75 people viewed this question
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
richie46
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
