Question about Dryers
Maytag Electric Dryer
How do you get the lint trap housing off the front of the dryer? I have the front off but don't know how to take off the lint housing.
  • robert samples May 11, 2010
    if you will send me the model number ill see if you can
Called a repairman!!!
Posted on Feb 13, 2008
My husbands wedding ring fell into the lint trap of our Maytag front loading dryer. Anyone know how we can get it out?
You can remove the lint filter to retrieve the RING, please do not put the machine to any wash until the filter and drain pump is removed and checked.
check this link.; Cleaning lint filter
Jan 01, 2013 | Maytag MDE9700AYW Neptune 174 Electric...
Lint problem
Yes, check filter assembly is not blocked.
Mar 25, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How to clean out lint at the bottom of lint tray?
remove front panel by releasing clips holding top to front. use putty knife and press in on 2 hidden clips. top will lift, hinged at back, then find two screws holding front to sides, remove and lift panel up and out. clog in these is very common at bottom of plastic duct on panel going into blower.
Jul 05, 2009 | Maytag PYE2300AY Electric Dryer
Individual package of detergent fell into lint trap of Whirlpool
HI, You should remove it. Here is how Normal 0 UNPLUG the dryer! Remove the two screws under the lint screen and pop the top up by inserting a flat blade screw driver in the gap between the front panel and the top. Remove the rear panel of the dryer and locate the four 5/16" screws that hold the lint screen housing to the bulk head. Pull the lint screen housing away from the bulkhead and reach in to remove the item that fell.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 28, 2009 | Whirlpool LER5636P Electric Dryer
Lint trap
http://www.pcappliancerepair.com/model-display.php This will show you how your dryer is put together. The lint has gone directly to the fan, where it could affect fan performance. You would have to remove the front off the dryer, and the cover off the fan area. It's not a bad idea to clean this area once in a while.
May 11, 2009 | Maytag Neptune MDE4000 Electric Dryer
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer lint throughout thr house
lint throughtout hte home is a sign tha there is a tear / or a disconnect of the dryer vent. check your venting
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Jan 21, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Jun 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top Dryers Experts
