Appliancepartspros.com has diagrams for that model. Here is the link that should show the upper rack
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=238625&diagram_id=20702#d20702
If that doesn't work, put your model number into the box on their home page -- it's pretty easy from there.
I have a KitchenAid so here is a photo of the clips with the rack installed. I hope this is what you want. I hope yours is the same. If you need more photos please ask.
Here is an exploded view of the rack i hope this helps i will look for another one for you
Not sure if this helps.
http://www.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209743110.pdf
page 10 has diagram of the rack with glassware.
Please post a comment to say if this helped otherwise i will find other diagrams that might help with more detail.
See page 10 of this link; (let me know if the link does not work and I will do what I can to make a better link. It works for me.) I also pasted it below the link.
Sure hope this helps.
http://docs.google.com/viewer?a=v&q=cache:8ZmueFLRBpIJ:www.kitchenaid.fi/ifudocs/5928_DW_Panel_Ready_Instruction_for_use.pdf+KitchenAid+Spray+arm+alignment&hl=en&pid=bl&srcid=ADGEESijiBGclcVyunez9-G4MOQufzYDLkSFe4r1PaAoB2QmCJFa444TJsZ0ezK0B3loAW_4t56Izhp2lAnYms9SFWutUgPSXUKFqLw-W3adUJWPEJpuwehgwznJCuhuXfqdGEecsMx8&sig=AHIEtbQWg50jifbPtONr0JqplgG_44yfjw
Try this link and then once it loads ZOOM to 200 % with explorer (lower RH corner) or thumbwheel on 3 button mouse. Hopefully you can see the clips you speak of there. There are 2 views TOP and BOTTOM you have to mouse over the thumbnails above the picture to get it to change.
http://www.repairclinic.com/SSPartDetail...
Hello. Here is a schematic for you http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%204172106.pdf
Regards, Joe
ps incase you need more here they all are
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KUDS24SE&siteCd=KAD
Thanks very much Joe for your prompt response but I am looking for an illustration that shows where the part clips to the upper rack. I mentioned in my problem that I needed to position the clips properly, however, that may be somewhat misleading. The clip that I am having difficulty with is what Kitchenaid refers to as the Wheel and Bearing Assembly, part number 9742983 (#3 noted on page 11 of the manual). It is a wheel that has a clip assembly as part of it. There are 4 of these, two on either side and they attach to the back part of the upper rack so that it can move along the upper track. If these aren't properly attached to the upper rack the whole rack falls forward from the weight of the glassware. Is there anything a little more specific that you are aware of? Thank you very much for your assistance. It is greatly appreciated.
Randy
Sorry, but the image on page 10 doesn't show the wheel bearing/clip assembly at the sides of the upper rack. I appreciate your assistance on this but I've got a feeling that there isn't anything, aside from getting a repair person in, that's going to give me a visual of precisely where these wheel bearings clip onto the upper rack. It's so frustration.
Thanks again,
Randy
No unfortunately this doesn't show the wheel assembly clip for the sides of the upper rack. There is a track that the upper rack rolls along. The wheel assembly enables the rack to roll in and out of the dishwasher unit, however, there are clips that must attach to the upper rack to ensure that the rack doesn't pull out too far and controls the level of the upper rack so that when dishes/glassware are loaded onto the upper rack it doesn't tilt forward from the weight. The positioning of these clips is absolutely essential to the proper function of the upper rack unit.
Hopefully this further explanation helps to resolve this problem and thanks again for all your assistance.
Randy
Seth765, unfortunately I can't see the picture. Can you please send it in another format, perhaps a PDF?
Thanks,
Randy
Good day Clay58:
Thanks very much for the image but unfortunately this is not the model I have. The clip that I am having difficulty with is what Kitchenaid refers to as the Wheel and Bearing Assembly, part number 9742983 (#3 noted on page 11 of the manual). Here is a link:
http://shared.whirlpoolcorp.com/assets/p...
Once again, I am grateful for the amount of effort put into resolving this issue.
Sincerely,
Randy
