Hi dnankey
To answer your question;
If your looking for the procedure to get into the service menu, here it is;
With the power off and with the remote
Press in succession info-menu-mute-power
You should now be in service mode and the rest is self-explanatory
Make sure to note any values that you may change.
Have fun
Hi again
There will be sub-adjustments for a variety of items that are in your menu,
But there is no magic button, these adjustment are usually used to correct fault that may occur after parts replacement etc.
Usually your tv menu by default is preset to operate within the optimal range of adjustment.
So unless there is a flagrant lack of for example;bright or sharpness you should stick to the standard menu.
Here is a tip for you;
When a guy tries to help you for "free" and gives you "free"advices you don`t go and slap him with a bad rating.
May make it harder in the future to get "free" help from a seasoned tech.
Have a good day
Hi barbu51 Will this get me into were i can change the color, mode, sharpness, brightness etc. for fine tuning the picture. Doug
