Question about Irons
Iron Cleaning I was wondering if you could please tell me how to clean a black and decker steam glide iron?
  • 4 Answers
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
Posted on Feb 18, 2008
How do I clean a not self clean ,quick press s506a , not self cleaning black and decker steam iron
Most steam irons can be cleaned deposits by emptying the water and replacing with white vinegar. Let it heat up and use the iron as normal - but on cloth rags instead of clothing. The vinegar breaks down and dissolves the mineral deposits inside that are responsible for sputtering and stains. You can reduce or even eliminate these deposits from forming by using distilled water instead of tap water in the iron - otherwise - run vinegar thru it when it starts acting up. The vinegar "trick" works great on coffee makers, too.
Dec 03, 2014 | Applica Black And Decker Steam Advantage...
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    Hi, I have a Black & Decker digital Evolution iron. It has worked fine in the past but now when I turn it on to any temp setting it starts flashing #8 and beeping. I have never seen the #8 on it...
    Try this cleaning procedure:
    Empty the iron's reservoir.
    Fill the reservoir halfway with white vinegar.
    Set iron to steam setting.
    Steam on a cotton rag allowing the vinegar to clean the holes in the soleplate.
    If this cannot be performed, or does not work,
    at Black & Decker's normal price point, it is simply easier to dispose and purchase new.
    Best regards,
    Feb 25, 2018 | Black & Decker AS675 Iron
    Black rubber burned onto plate of iron
    Here is a tip that will help you with that problem...
    Cleaning a Steam Iron Soleplate
    http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
    heatman101
    Apr 12, 2010 | Black & Decker ProFinish X750 Iron
    How do I clean my iron? The iron part on outside
    Here is a tip that will help you with cleaning the bottom of your iron...
    heatman101
    Apr 05, 2010 | Black & Decker Steam Xpress AS250 Iron...
    My new black & decker steam advantage iron won't glide over clothes, it's almost like it wants to stick to the clothes.
    check the instruction manual and see if it says to clean the surface before using it , if not try cleaning it and use it on something old in case it wants to scorch the fabric
    Dec 11, 2009 | Black & Decker Irons
    How do I clean my Black N Decker Advantage Iron
    I work for Black & Decker customer service. Our number is 800-231-9786.
    You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
    Care and Cleaning
    This product contains no user serviceable parts. Refer
    service to qualified service personnel.
    It is not necessary to empty the water reservoir after each
    use of the iron, if you iron frequently.
    To empty the iron, hold the iron over the sink with the tip
    pointing down. Water will stream out of the water fill
    opening.
    TO CLEAN THE OUTSIDE SURFACES
    • Unplug and allow iron to cool completely. Wipe the
    soleplate and outer surfaces with a soft cloth
    dampened in water and a mild household detergent.
    Never use abrasives, heavy duty cleansers, vinegar, or
    scouring pads that may scratch or discolor the iron.
    • After cleaning, iron with steam over an old cloth to
    remove any residue from the steam vents.
    ABOUT THE SELF-CLEANING SYSTEM
    • Use the self-cleaning system to flush out minerals and
    lint. If lint is allowed to accumulate in the vents, it can
    scorch and cause brown spotting.
    For Models D2000 and D2020: Clean about once a
    month.
    For Models D2010, D2030 and D2035: A "CLEAN"
    indicator will appear in the digital display to notify you
    when your iron needs cleaning (A).
    • Fill the iron as described in "How to Use" but keep the
    water level below the MAX line. Plug in the iron, set
    the temperature to 6, and stand the iron on its heel
    rest. Allow to heat about 3 minutes.
    • Unplug the iron and take it to a sink. Holding it
    horizontally over a sink, move and HOLD the variable
    steam dial in the CLEAN position ( ). There may be
    some hissing and spitting while self-cleaning. This is
    normal.
    • Stay clear of HOT steam and boiling water as it comes
    out of the vents while lint, scale, and minerals flush
    through! Continue to hold the variable steam dial in
    the CLEAN position until all the water has emptied.
    If necessary, rock the iron side to side and front to back
    to empty it.
    • When finished, release the variable steam dial, stand
    the iron on its heel rest, and plug it in. Heat for about
    2 minutes to dry out any remaining water then unplug.
    I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
    Please let me know if I can be of further assistance.
    Jul 03, 2009 | Black & Decker D2030 Iron
    How do i use the self cleaner
    Care and Cleaning
    opening.
    month.
    normal.
    to empty it.
    Jun 26, 2009 | Black & Decker D2010 Iron with Auto...
    Cleaning a self cleaning iron
    Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
    May 22, 2007 | Black & Decker D2030 Iron
    Irons Logo
    542 people viewed this question
    Top Irons Experts
    Marvin
    Marvin
    Are you an Iron Expert? Answer questions, earn points and help others
