Question about Xerox CopyCentre C20 Black and White Copier
RX paper tray full
I'm getting this error on my CopyCentre C20. I see no paper jams and recycling power doesn't seem to make error message go away. Any ideas anyone??
    President:
  • 2,072 Answers
Yep, easy fix. Look into the area where your copies come out, between the paper try and scanner. look towards the upper back and you will see a flag sensor, about 2 inches wide and 1 inch in height. It has come out of the 2 clips it snaps into. Carefuly move it around until you line it up properly then snap it back into the clips it mounts to. You may have to gently squeeze those clips together to hold the flag in place.
That is your problem. Easy one to resolve.
Posted on Feb 12, 2008
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
My Xerox CopyCentre C20 doesn't always print the entire page, as if it is only scanning part of the page. It happens when the original is placed on the glass surface as well as when the original is sent...
the paper size detector may not detect the original size of the document check the paper tray indicator light on the panel and make sure the direction is the same with the original document onthe glass
Aug 26, 2010 | Xerox CopyCentre C20 Black and White...
Had a paper jam, cleared jam. Had made probably 30 copies prior to this happening and then the copier doesn't work - open heat error
You probably had an overheating condition that opened the thermostat of the fuser.You'll have to replace the fuser assembly because it is not a resetable thermostat.But before you do that, check the wiring (two smal white wires exitin from the fuser) for an open cirquit or a bad connection to the terminals.
May 27, 2010 | Xerox CopyCentre C20 Black and White...
HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Feb 15, 2010 | HP LaserJet P3005n Printer
Copycentre c20 has open heat error message. How do I replace fuser unit?
The fuser unit for this machine can only be installed by a technician as the fuser unit itself is not for sale to consumers.
Nov 19, 2009 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre prints out faint copies. DIrty?
You have a dirty laser, I will tell you how to clean it when I am awake.
Mar 20, 2009 | Xerox CopyCentre C20 Black and White...
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Xerox copycentre c20 paper jam in 2 how do i get it out please
Unplug the machine, open the right door. Get a phillips screwdriver.
Look on the upper portion of the paper path, you will see an assembly with yellow waning stickers that say HOT. There are 4 silver screws on that fuser assembly. Remove those screws, and unplug the white connector. Pull back toward yourself to remove the fuser.
Lay it down and remove 2 silver phillips screws , it will open up and you can remove the paper. Make sure the machine has been off for a half an hour or so, It is hot. Take a good look at the black aluminum coated roller on top. See if it looks smooth and clean, If it has a lot of toner built up on it, you will have to repalce the fuser or it will continue to jam and give you ghost ( light reprinted) images up and down your page.
Also the M20 does not handle large black ares on a page such as a picture or magasing cover being copied. Largs solid areas tend to stick to that heat roller. If you do copy a photo, try and allow about 2 inches on the top of white. Just move your original down on the glass about 2 inches from the edge. 2 inches to tie right of the edge of the glass.
Jan 18, 2009 | Xerox CopyCentre C20 Black and White...
Document jam
Sometimes powering off and pulling the power from the wall will reset an error like this. If not there will be small flag sensors in the paper path that should be spring loaded. Make sure the springs have not come off and the sensors are moving properly. Next is to make sure the data cable the connect the document feeder to the machine is tightly connected. You should have the power disconnected when re-seating this cable. Also make sure the hinges are not broken.
Dec 10, 2007 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre C20 Black and White Copier Logo
237 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
