Question about Brother IntelliFAX 4100 Laser Fax
Problem with color of fax
Hi!
i'm having a problem with my fax machine.
when i receive a fax it comes over faded. but i already replaced the toner and i just replaced the drum. could you please help!!!!
  • lilalien Feb 15, 2008
    hey guys!!
    thanks for the reply!!
  • lilalien Feb 19, 2008
    hey guys!!
    your solution worked great!
    thanks a million! =)
    Problem Solver:
  • 8 Answers
Make sure if you blow it out that you blow out the drum unit itself,as this is likely causing some of your problem
Posted on Feb 15, 2008
    Scholar:
  • 95 Answers
First make sure you have fresh paper! Believe it or not, damp paper can make a page faded like that. Also try blowing it out (with the cartridge out) with a can of air... maybe you have some toner lose on the laser glass... it's on the inside top. If it started after you replaced the drum, you may have a defective drum itself.
Posted on Feb 13, 2008
Print is not clear , when we are printing light print is coming, we have already changed the cartridge but the problem is still there
You need to see if the problem is coming from all of the colors or just one. You can print an internal test sheet or just print something with cyan, magenta, yellow and black to see if one or all of them are faded.
If all of the colors are faded and you have already replaced the cartridges then check the fuser unit. It is possible that the toner isn't fusing properly.
Sep 10, 2009 | HP Color LaserJet 2600n Printer
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Right side of printed page is faded
pull out your drum unit and look inside machine above where the drum would be. you should see a black assembly that runs left to right with a "****" glass. may need a flashlight. clean that glass off with a clean rag. sometimes toner "scatter" will get on glass and cause this.
let us know,
razors
Mar 26, 2009 | Brother IntelliFAX 4100 Laser Fax
Red color faded and red color is mis-aligned.
Hi We've been seeing alot of the HP Color Laserjet range of laser printers coming through with a "prints lightly with red" or "red is faded" fault report, we've been able to resolve the problem mostly by cleaning the scanner. Misalignment is normally resolved therafter by calibrating the machine using its calibration function. (if it has one) Wouldnt suggest this gets tried unless one is familiar with stripping and reassembling these machines though. Hope this helps.
Mar 23, 2009 | HP Office Equipment & Supplies
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Fax
You probably need new ink / drum / toner.
Oct 13, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Faxes come out faded
possible causes are low toner, worn drum, bad fuser, or defective polygon laser scanner, for a laser based faxes. for inkjet based fax machines faded prints are usually caused by low ink levels, worn printhead/s.Good Luck!
Sep 16, 2008 | Office Equipment & Supplies
Brother MFC 8300 Fax Machine
No, the toner is clear on the whole page except for the right side where it fades out and you can barely make out the words. Everything else on the page is fine. The drum still has 17% of life left in it.
May 08, 2008 | Brother MFC 8300 Laser Printer
Ready Memory Received
Dear guys, your toner cartridge is low and as a preventive measure, the unit stores the faxes in order to give priority to copying and printing. If you are using remanufactured cartridges, the unit might not be displaying the low toner warning.
Jan 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Faded areas showing up on copy
jhahn, It sounds like your machine needs a through cleaning from a repair company. There are many good independant vendors out there that will come out for less than $100 for a time and material call on your fax. If you want to try to do something on your own, you can take a can of air and spray the air throughout the machine. If you give me the city you live in, I can give you some ideas for some companies close by if the canned air doesn't work. john
Nov 21, 2006 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
