Question about Sony KP-48S65 48" Rear Projection Television
KP-46S4U lose picture after a few second blink of brightness
I have a Sony rear projection TV KP-46S4U of 8 years old. Recently it often loses its picture wit sound remaining, or completely shut down (in a protection mode) after a few second blink of brightness. Once I power down the TV and power up again, it works fine again, but doesn't last long. can any expert help me please? Thanks.
  • PatrickWu Feb 13, 2008
    Hi Thanks for the help. It is the TV screen blink (or flash) with unstable brightness, sometimes very bright, and suddenly very dark, and then loses the picture with the sound remaining, or completely shut down after flashing. The LED doesn't blink. It comes back to life again if I power it down and power up again, but it doesn't last too long before this happens again. Thanks.
    President:
  • 4,402 Answers
Does the from led blink if so how mant times pause then blink again?
Posted on Feb 12, 2008
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
When i turn on the tv it starts blinking and the projecters blink very bright an after a few seconds it will trun its self off
Just a guess, but I'll bet the red power on indicator lamp blinks 8 times when it does this, yes? If so that is a problem with the high voltage circuit.
Jun 30, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
Thanks.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
My Sony 54" Grand Wega rear projection TV is 4 years old in Sep. It has started losing picture and sound for a few seconds then comes back on. It is getting more and more frequent. . . like six times in 5...
A spent bulb will cause the whole set to go off. If you have not changed the bulb in all of these years, first you are lucky, and second that is probably the cause of your problem.
Aug 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
TV picture
its not the time for new tv yet.as the problem you r facing is not a major problem.
Check for multiple poor solder connection on the sweep/power supply board.
or.
just need to balance the three colors red,green and blue that may help. remove the front covers and look for black module that have screw and focus controls just move little bit left or rightbe carefull because you can loos the picture
May 02, 2008 | Sony KP-53XBR45 53" Rear Projection...
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Televison & Video Logo
189 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
