Question about AEG T57800 Electric Dryer
LG electric stackable dryer
I have had my dryer for about a year and a half which I purchase new. I recently moved and had a new 220 line installed for the dryer however when the electrician moved the unit back towards the wall, he cracked the aluminum vent and the dryer was blowing lint into the air. I was not aware of this right away so I was running the dryer for about a week when I noticed lint on the floor. The last time I used it, I set the timer to dry some bath towels and it started up, but when I went to get them out, they were still damp. The dryer will not turn on at all. No lights, no sound, no movement. I unplugged the unit and re-plugged it as well as checked the breaker and everything seems to be fine. I have not been able to move the unit out to check the back, but do you think the vent could be blocked causing this unit to shut off as a safety feature. Please advise. THANK YOU~
  • 958 Answers
Based on your story, with no lights not even a sound that indicated you have press a button, its more likely that there is no power. check your outlet. there should be a 220 volt on the outer prongs and 110 v on the middle and against either outside prong. you may have a 220 but not the neutral which is 110 which is the voltage of the control. in some homes, even the neutral is attached to a circuit breaker. i hope i was able to help...
Posted on Feb 12, 2008
I am trying to hook up my stackable washer and dryer. I havee a 220 plug 30a what do I need to do so I don't have to go back to home depot and get whole new plug in and plug?
If the unit has a 30 amp/220volt plug, then you will need a dedicated 30 amp outlet from a 220 volt line from the panel. You can not switch the plug to work with a regular (15-20 amp) outlet. Have an electrician install a 10 gauge 220 line from the panel to the unit. good luck!
Aug 30, 2011 | Whirlpool LTE6234D Top Load Stacked...
I have a lg dryer with a 220 electric hook up plug and in my house there is only a 110 electrical outlet. is there any way I can just change out the cord to a 110 electric cord and use it?
No. the new dryers have to have a 220V power. You first have to replace or add a 220 outlet on the wall that matches the connector on the dryer.
Jun 26, 2011 | LG Dryers
WE HAVE HAD THE LG DLE2532W DRYER JUST OVER THREE YEARS. RECENTLY, WE HAD TO REPLACE THE DRUM BECAUSE IT HAD A CRACK IN IT. NOW THE REPLACEMNT DRUM (FOUR MONTHS OLD) HAS A CRACK IN IT AND THE DRYER IS NOT...
Here's one place you can order a new drum. However, if the drum has cracked twice in four months you need to find out if there's something else with the dryer that's making the drum crack. You also need to think if you're doing something like putting shoes in there or something that's stressful on the dryer.
Nov 01, 2009 | LG DLE2532W Electric Dryer
It takes at least 2 60 minute cycles to dry clothes. Not even 2 years old yet. Not a new problem has always been this way. What is the deal.
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
Apr 14, 2009 | LG DLE3777 Electric Dryer
Dryer not drying sufficiently
Clean out the vent air lines. If partially blocked or bent/kinked will cause this.
Mar 27, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Stackable washer dryer
hi thanks for the question the washer has a separate cord for 110 volts see if its plugged in thanks the appliance doc
Sep 27, 2008 | Kenmore 62602 Electric Dryer
Install 220 outlet for electric dryer or trade it for gas dryer?
Thanks for all the input!  We reached a compromise in hiring an electrician who was willing to come out today and install the connection for half what everyone else quoted...on a Sunday!  The laundry piling up in the corner was very persuasive in convincing us that your advice (in the end, we'd need a professional no matter which way we went) was prudent.  Thanks. jersey p
Sep 13, 2008 | Kenmore 63942 Dryer
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
AEG T57800 Electric Dryer Logo
110 people viewed this question
Top AEG Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you an AEG Dryer Expert? Answer questions, earn points and help others
