Question about Cuisinart 12 Cup Digital Thermal Coffee Maker - BLACK
Metal Tasting Coffee
I bought the Cuisinart DTC-975, two months ago, followed instructions for cleaning. after One month the coffee tasted like metal. I ran vinegar through the cycle followed by two times clear water, that lasted two day of good tasting coffee and i am back to the metal tasting. Please help.
  • Anonymous Mar 29, 2014
    My Bella Coffee maker has a bad (oily) taste. I hae run the clean cycle several times.
  • 2,039 Answers
Vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Posted on Feb 12, 2008
My coffee pot is black inside & using vinegar does not clean it
Use a coffee pot cleaner such as Dip-IT. Walmart sells a product in the coffee maker area that is for cleaning the coffee maker. It cleans the coffee pots too.
Feb 24, 2011 | Cuisinart DTC-975 Coffee Maker
Lost instruction manual. How do I clean coffee maker to get rid of strong acid taste coffee? MoldelB60 single cup coffee maker
Most coffee pots are cleaned by running 1 part white vinegar and 1 part water. Just put in the reservoir and run a cycle. Once completed, run again with 1/2 pot of water only and it will clean it. If you use your pot daily, this should be done once every few months. If you have foul tasting coffee, you should use bottled water to rectify that. Plain tap water has minerals that dilute the taste of the coffee and over time build a residue in your pot.
Oct 09, 2010 | Keurig B60 Coffee Maker
Very slow, 40 minutes to make 8 cups
Run a 50:50 mixture of cold water and white vinegar through the machine several times. Allow the mixture to cool off after each run and use a filter to catch the debris that comes out of the heater/pump. Run clean water several times to remove the vinegar taste. This works great on our old Mr Coffee and lasts for some time before doing it again. Hope this helps!
Sep 26, 2010 | Cuisinart DTC-975 Coffee Maker
Coffee not tasting good
To make the self-clean light go off, just unplug the coffeemaker for longer than 20 minutes. As far as not tasting right, did you try flushing the vinegar out of the coffeemaker using plain water, or water mixed with 1 tbsp lemon juice per cup? Also, get rid of your current charcoal water filter - after time, it will disintegrate, and your coffee will have a hint of charcoal.
Apr 11, 2009 | Cuisinart DCC-1200 Coffee Maker
Funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
Apr 03, 2009 | Cuisinart Coffee Makers & Espresso...
Coffee tastes like plastic!
We have had our DCC-1200 for 3 months. The plastic taste occurs about every 3rd pot, and it does NOT get better. We've wasted over a pound of coffee. Cuisinart says we are the only people in the world with the problem. Well, I guess not...
Jan 16, 2009 | Cuisinart DCC-1200 Coffee Maker
WORKS GOOD
Run a mixture of 50% vinegar and 50% water through the unit, just like it was coffee. For the caraffe, let the vinegar sit in the caraffe for 20 minutes, and then scrub it out with a soft sponge.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart DTC-975 Coffee Maker
Bad tasting coffee
tell what does it taste like is it to hot burn let me now but i would descale it first not with venagar but with coffee maker descaler start with that and let me now what the taste
Jan 10, 2009 | Sunbeam COFFEEMAKER 10C BLACK DR13
Cuisinart coffee maker... How do I clean the inside metal craft?
A clean coffee maker is essential to good coffee. Residue of stale coffee oils will interfere the brewing that caused 2-3 cups only produced. It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
I took everything out, got a small piece of fine sandpaper, held the plunger in with a pencil, turned on the grinder and sanded the round top portion of the grind basket driver. It takes a few times to get a good snug fit that’s still easy to remove.
The instruction manual that came with the pot will tell you to use one cup (measuring cup) of "white vinegar" and fill the rest of the reservoir with regular water. Turn it on and let it perk the mixture through the system. Then perk a couple of pots of plain water to flush out the rest of the vinegar.
The books say to do this once a month to keep things clean and the coffee tasting great.
A professional machine that is plumbed into a water supply must be thoroughly disassembled, and each part soaked in acid, and manually cleaned. Unless your water is exceptionally hard (you should have a water softener inline with the machine in hard water areas) this should only need to be done every 5 years or so. Heads and screens and filters should be soaked every day in a cleaning solution available from any professional machine supplier. A machine that is not plumbed should have a small amount of Puly brand cleaner added to its tank, and run through several cycles every 3 months. Puly is available thru machine suppliers, but there are also several other brands that do the same. Visit your local coffee machine shop for a good cleaner.
Hope this may help;
Regards,
VOTIT
don't forget to rate
Aug 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee tastes like metal
THIS HAS NOTHING TO DO WITH THE COFFEE. This has to do with water filter system and most importantly descaling of machine, as over time the metals in side machine and tubing get a mold type build up. Its a chemical reaction from the water and tubing and the coffee and metals. To 100% solve this, descale the machine with water and vinegar mixed. Do this a couple of times and use bottled water to fill water tank if you do not have a good water filter tap system. I have been the espresso business for over 16 years with 4 locations, and it has nothing to do with the coffee. If it was the coffee or poor coffee it would tasted burned or bitter, but NOT tasting like metal.
Please rate my solution as you see helpful, Thanks Mike Espresso Expert
Jul 02, 2008 | Dacor CM24P-1 Coffee Maker
Cuisinart 12 Cup Digital Thermal Coffee Maker - BLACK Logo
494 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
