Question about Nikon Coolpix 4300 Digital Camera
Battery charging out of country
Can the charger for my camera be charged safely in Cuba as their power is different?
  • 667 Answers
You should be fine. WikiTravel
Look under the flag on the right
Posted on Feb 12, 2008
Will not charge when plugged in
have you tried an external battery charger and a different battery?..... maybe its the camera not sending power to the battery..... or the battery is good and the camera is dead, the external charger will help you decide where the fault is.
Mar 09, 2014 | Nikon COOLPIX Cameras
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Looking for a ac power cord for this camera
You only can safely use an original Canon power cord when you want to charge the batteries in the camera. That can be expensive. Why not buy an normal battery charger, to charge the two batteries outside the camera.
I know it looks convenient charging in the camera, but I charge all my batteries in external chargers. Is also much safer for the camera.
Jan 26, 2014 | Canon Powershot A1000IS 10MP Digital...
My video camera (SDR-H18) wont charge...the battery lights up when charging but when i put it in the camera the camera wont turn on...whats the problem?
It sounds like a bad battery. If you have another battery, or a direct power plug for the camera, try those to determine if the camera itself functions. If so, you can safely assume the battery is the problem. If the power plug works but not a different battery, you may have dirty or corroded contacts where the battery attaches to the camera. If changing the battery works, the old one should be returned if under warranty, recycled if not, or you could leave it on the charger for several hours to see if it can complete a charge at all. If not, get a new battery.
May 05, 2011 | Panasonic SDR-H18 USB Hard Drive
I have been use sony cycle Energy Rechargable batteries AA 2000mAh. They are properly charging. But now I'am purchased another sony cycle Energy Reechargable batteries AA 3000mAh. But they are no charging...
It's likely your charger. You probably own a "fast charger" but it's also probably designed for your lower mAh power batteries. The charger does not understand the power difference of your newer high-capacity battery, thus it is automatically stopping the charge before completion sensing something is wrong. You'll need to either purchase a newer charger, clearly stated capable of charging 3000mAh batteries. An alternative is to use an older "trickle" charger (one of those that charges at very low power slowly overnight). These don't automatically turn off when the battery reaches full charge, thus will charge your battery.
Sep 19, 2010 | Cameras
Camera works fine with power supply cord connected. It will also charge the battery if connected to camera and power supply connected to ac outlet. Checked battery and it has 8.32 Volts stored in it after...
Your charger is probibly the problem i had a friend of mine that had the same problem but different camera i told him to get a new charger he did and it worked so yoyu do the same goodluck:) please rate this solution...
Jun 06, 2010 | Cameras
My camera wont charge
have you check the charger? or is there a power on the outlet? try to charge it from different power source
May 25, 2010 | Kodak EasyShare V1003 Digital Camera
Can the digital camera battery charger be used overseas?
Yes! dont worry about that. You may also check the voltage of the charger if its 100V-120V it means its capable to charged On a walloutlet that has 110V- 120V
Nov 09, 2009 | Kodak EasyShare C743 Digital Camera
Can i charge the camera other than through the usb cable ??
Hi!
USB charging is not possible. You need to have the battery charger to be able to fully charge the battery. This should come along with the camera kit.
USB charging is possible if you will buy this: http://fujifilm.co.uk/consumer/digital/digital-accessories/usb-chargers-travel-adaptors-153171/world-adaptor-plus-usb-charger
"For charging by USB, simply change the head and plug in your iPod, mobile phone, PDA or any other 5V USB powered device to keep it fully charged wherever you are."
Aug 25, 2009 | Fuji Finepix Z20fd Digital Camera
Camera won't charge
If your camera appears to be in working order, your charger or the power outlet may have an issue.
With all connections intact,
1) Please try to connect the charger to a different power outlet and try again.
2) If the charger doesn't appear to show any indications of charging, try with a different charger.
3) If the charger works fine, there may be something wrong with the battery - or the camera. In such a case, please consult an authorised service center for a resolution.
Thanks!
Jul 19, 2008 | Sanyo Cameras
Nikon Coolpix 4300 Digital Camera Logo
140 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
