Question about HP LaserJet 2840 All-In-One Printer
HP LJ 2840 problem
Incorrect yellow error displayed. Yellow cartride appears to be in the midcycle position. How do I reposition the cartridges when the button will not advance the cartridges.?
  • 1 more comment
  • bottleman Mar 09, 2008
    I have a HP laser Jet 2840 printer. I have replaced all the cartiages and still the incorrect yellow message appears on the printer screen. I need help in fixing
  • NealR Jun 10, 2008
    I have the same problem with the same machine (HP 2840). However, I am unable to locate the clutch in order to fix it. I require a more detailed description of where the clutch is.
  • Sergio Pagoada
    Sergio Pagoada Feb 01, 2014
    i am having the same problem, and i am having the same problem, i came to the conlusion that it was something greater than the actual cartridge, but it was the only way for the printer to send a message on the yellow cartridge positon. so i took out the image drum, and all the cartridges and looked aroun, and i notice that the gears werent aligned and that can be seen on the yellow cartridge position, i believe its called error 54.2 and you can see how to actually fix it, its realigning the carasoul. hope you guys have luck with it, as for mine i think its something greater than that as i get a loud noise as if it were hitting something
  • 43 Answers
I'm about to dive into the printer and change the carousel. I'm having the same incorect yellow msg even when the cartridge is not inserted... I'll be back with further info.
Posted on Mar 18, 2008
  • 2 more comments
  • Sebastian Munteanu
    Sebastian Munteanu Mar 18, 2008
    Mike Wiggs - try to manually move the carousel by inserting a thin screwdriver into the carousel clutch - top/right under the cover - there is a white guide for that. Do this with the power plug out.
    Sebastian Munteanu Mar 19, 2008
    Yeeey. Replacing the carousel solved the problem. I had to replace the Y toner cartridge as well...
  • Sergio Pagoada
  • Sergio Pagoada
    btw im not the best typer, im the person who has all types of typo mistakes like switch around letters, or forget to add a letter or add too many letters, hopefully you can forgive me
My printer Hp Color laserjet 2840 is given an Incorrect yellow initially, after i bought the catridge it is telling me of 52.4 error how to go about it.
Take the cartridge out and reseat it. If you bought a compatible toner I would order an OEM HP brand toner. These machines don't work well with compatibles.
Jan 20, 2017 | HP LaserJet 2840 Printer
Incorrect Yellow
Are U installed specified yellow cartridge? Chk with old cartridge & chk for the message.. Same error? there is a mechanical issue, carousel unit might be misaligned..To align it technical skills required, better go to the nearest service center.
If different error replace with another cartridge.
Feb 22, 2014 | HP LaserJet 2840 Printer
I have hp laserjet 2840 i replaced imaging drum and black cartrige now my printer says incorrect yellow and i cant get it go rotate or print?
If you used a compatible cartridge (as I assume) the problem is with the cartridge "CHIP", very common on compatible cartridges, return the cartridge or replace the chip. The chip is on the top of the cartridge and can be remove.
Dec 01, 2010 | HP LaserJet 2840 All-In-One Printer
The screen says incorrect yelo and the cartridges will not rotate.
What is the brand of the yellow cartridge?
By the by, are you able to take the yellow out or is it stuck in the carousel?
Oct 15, 2010 | HP LaserJet 2840 All-In-One Printer
Incorrect yellow of HP laserjet 2840
Turn off the printer and open the cover and manually rotate the assembly for the toner.
Jun 24, 2009 | HP LaserJet 2840 All-In-One Printer
Install yellow cartridge when already installed on display
I would try removing all cartridges, turn of the printer, turn it back on and wait for the error messages, then reinstall the cartridges.
Jan 27, 2009 | HP LaserJet 2840 All-In-One Printer
"incorrect yellow"
you need to remove the plastic cover in order to remove the problem cartridge...
Sep 16, 2008 | HP LaserJet 2840 All-In-One Printer
Re-installing yellow cartridge in HP 2840
There is a gray button right of the LCD display that has a black arrow circling clockwise and four color dots (magenta/black/cyan/yellow). Push it until you see the "Rotating to Yellow" in the LCD display, then open up the top of the printer by pushing the big gray latch next to the picture card reader at the right front of the printer. You now have access to the cartridge. pull it out and examine it. If it is a new cartridge, check to see if you pulled the plastic dam strip out (which keeps the toner in place in shipment etc).
Sep 07, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2840 All-In-One Printer Logo
1,399 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
