Question about Kyocera FS-3900DN Laser Printer
Prints strange characters
My fs-3900 prints strange characters first time in the morning. After warming up, it runs great. Any suggestions on the problem. Thanks Dave.
  • 51 Answers
You will need to do a fimware upgrade on the machine.
Posted on Mar 27, 2008
Dark lines fs 3900
The lines are more than likely caused by either the Drum, Developer or Fuser unit. I have found in many cases that if non genuine toner is being used this will give you poor quality images. You can try using genuine toner which may resolve your issue but you may have to run a few hundred prints to clear out the old toner before the image improves.
Apr 15, 2014 | Kyocera FS-3900DN Laser Printer
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Apr 04, 2011 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
It prints gibberish before the print job.
I have had this happen before, this could be you need to change the drum kit on the printer itself, check the indicator light.
Jul 28, 2009 | Dell 1720dn Laser Printer
TC 212 & 214, hard to start but runs well after starting.
Possibly a Battery going bad, check your connections, if they are tight then you may need a new batter, if they are loose, then tighten them. (If the problem persists after tightening, have battery checked)
Mar 14, 2009 | 1995 Ford Taurus
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Kyocera FS-C5016N
when you open the left cover you will see some green plastic things. If you pull these towards the left they will clean print heads and charge coronas.
If this does not fix the problem the you will have to remove the dev and drum units from the machine.
The print head sits on top of the drum unit and can be levered off with the three tabs gently lifted.
the entire print head can be remove once the black cover has been unhitched from the sides.
The print heads are not screwed in and what ever you do DO NOT TOUCH THE SCREWS on the print heads as they are only for density adjustment
Aug 08, 2008 | Kyocera Mita FS-C5016N Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Kyocera FS-3900DN Laser Printer Logo
560 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
