Insignia ns-lcd15 Hi I have an Insignia tv with power issue. My tv made a crackling sound through the speaker and powered off now it when I press the power switch the green light comes on but no display. i have tried the flash light trick to see if I see an image but there was none when unit was on. I was woundering if this is an inverter board issue or something more serious wrong. I able to repair it but I cannot find any Schematics for this unit. If I had one it will help out a lot. To determine the problem. I was wounder if any had similar problem and if so how and what did they fix to get it working again? Thank You..
The problem i have seen is the main surface mount IC ( the one with the heat sink) runs hot and the connections go bad from expanding. poor design. somtimes pressing down on the heat sink while its on will yield a picture and then goes out.
Posted on Sep 15, 2008
I have an insignia ns-lcd15 which I purchased about a year and a half ago and suddenly there was no sound. Occasionally, I get a crackeling noise, but nothing else. Any thoughts?
Posted on Aug 12, 2010
Tv has sound but no picture
This is almost certainly a problem with the backlight power supply, not the ac adapter. If the backlight isn't working, you will see nothing on the screen.
Aug 30, 2012 | Insignia NS-LCD15 15" LCD TV flat monitor...
Can I change the font size for closed captioning on model no NS-LCD15-09 TV
To change the text size of close caption, you have to enter its service mode options. For more details, check this link by search to your TV model number
Feb 11, 2012 | Insignia Televison & Video
Audio crackle from any hdmi device plugged in to EITHER HDMI port
Hi, Sounds like bad HDMI cables. I've had this issue myself and you look at the cable and you can't see anything wrong with it but there is internally. My suggestion is to get a new HDMI cable.
May 12, 2011 | Insignia NS-LCD37 37 in. LCD TV
We just bought a NS-PDP50HD-09 Insignia 50" plasma
Although we would not be able to assist you with power issue you're having with your TV, I can assure you that the issue with your new HD Insignia TV not turning on has nothing to do with the DISH Network receiver you have connected to it.
Phillip Chang
DISH Network Customer Service Representative
Feb 14, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
Plugged in no power light or picture cord checks out good
replace power supply. multiple components died on power supply to many to replace and some to small for hand solder. cause cheaply made power supply
Apr 27, 2010 | Insignia NS-LCD19 19 in. LCD TV
There is no sound on my insignia flat screen what do I do
Try hooking up the powered PC speakers to the AUDIO Line out RCA jacks to see if you get the sound there, if you do, then the problem can be in the power amp section (make sure to check the on screen sound setup menu that the speakers are not set to OFF), if no sound at the RCA jacks either, then the problem can be in the sound processor circuit in the main board.
Nov 09, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Insignia NS-LTDVD26 won't turn on
It is always recommended to ensure that your TV is powered down before connecting or disconnecting cables. Unfortunately, it is likely that your TV requires service for the power issue.
Aug 06, 2009 | Insignia NSLTDVD26 LCD TV
Insignia NS-LCD37 TV - no sound
Start checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
May 22, 2009 | Insignia NS-LCD37 37 in. LCD TV
Do I need a convert box for my tv.
the screen is not as large as it could be......has black frame around it.....also need a instruction booklet
Dec 12, 2008 | Insignia 15 in. Flat Panel LCD HDTV
TV does not power on. No Stand by light either.
Your power supply is shorted out. Get a good repairman to fix it..."exspensive" repair if you screw it up.
Apr 30, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
436 people viewed this question
Top Televison & Video Experts
Electro Med Services...
