Hi friends!! i have a china mobile N95.. it keeps on restarting when i inserted a sim card. but it works without a sim.. please help me.. email me at [email protected]... thanks a lot for those who can help me...
After putting a sim card, it restarts for several times but after removing the sim card it works normally. please what can i do to solve the problem?
This may because your cellular phone cannot recognize the sim card,may be the sim card doesn't insert deeply or the card slot is loosening,you can
try to insert it deeper and tighten the slot.
dear,
charge the phone with its own charger. dont use universal charger or other nokia mobile charger. china mobile have this problem. so charge the battery with the charger that came with it. hope ur problem will be solved.
regards,
you should try and have the firmware on that mobile reflash but you should contact the store that you bought it from seeing that it is not an original but just a clone i am not aware of any firmware for those phones as yet.
hte thing is...ur phone is handset bundled offer phone..so til the validity ends on ur new sim card..the phone is designed to detect only new sim..so ucant change til validity ends...or u may approach any private local mobile repair shop..i wont cost u much..
ne other prob's do tell me..N plz plz do rate me cya
try cleaning your sim tray with ip alcohol i.e, spirit applied after injectionis given by docs , or nail polish remover i.e, acetone.
that should take care of your problem other wise tighten the screws of the phone or loosen it a bit , try with both the permutation combinations that allows for proper sim recognition,
the above should do the needful, otherwise lastly will have to reflash the entire piece to some mobile repairer would hardly takes few minutes and is very cheap too.
even if that doenot solve then the sim tray has to be resoldered or then the sim ic is the culprit only a qualified repairer can do that.
weel I suggest you select a main sim on sim menu. Put your simcard in the left side if you have dual sim slot then open the cellphone, go to menu and select sim switch, then select the main switch. it will automatically restart your cellphone. after that you wait and see good signal bar and your operator logo what ever it is. now its ok. hope it will help you......
First of all the default password for the phones are 1122, secondly about the sim restarting problems, u know its all about network, chinese mobile have put there own configurations in these mobiles, therefore before using your phone, start it without sim and reset factory default.. delete all network configurations and then put your sim and start your phone.. if the problem continues then try putting your sim in another mobile phone and reset factory default for the other phone.. then put the sim again in the nokia or nokLa.. Anyway im tired typing friends.. In case of any further informations just add me on your messengers.. Till possiblem i'll guide you step by step..
Were can i get the Nokia PC Suite 6.85 for N95? because my N95 china
phone can't connect to my pc. the error is MT6227. Can you help me to
this problem??? pls reply to me thanks
ihave a same problem
