Question about JVC KD-S570 CD Player
JVC KD-S575 Hi, I have a JVC KD-S575 Car front loader CD player. I do not have the original jumper connector block that fits to the rear chassis of the loader. Is it possible to give me the pin config of the block so I can make up one. Many thanks, Mark my email address is upmarket@telkomsa.net
    Brigadier General:
  • 6,966 Answers
Most versions of the JVC KD-S575 uses the 16pin block connector as shown below. It is available at the JVC Accessory Store.
Below image shows the pin's alphanumeric designation.
Color coding and where connected is shown below.
A2 Brown - cellular phone/mute
A4 Yellow - Always on B+12 (such as the battery's positive terminal)
A5 Blue/White - Power Antenna
A7 Red - Accessory or switched +12VDC
A8 Black - Chassis/Ground/GND
B1 Purple - Right Rear +
B2 Purple/Black - Right Rear -
B3 Gray - Right Front +
B4 Gray/Black - Right Front -
B5 White - Left Front +
B6 White/Black - left Front -
B7 Green - Left Rear +
B8 Green/Black - Left Rear -
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
  • Louie  Role
    Louie Role Feb 12, 2008
    Hi again,
    Glad to be of assistance and appreciate the rating.
Hi,Excuseme.I have 16 pin connecter of the JVC KD-S575. But,color of the wires does not match the position of the pin.I want to know the position of the 16 pin connecter of the JVC KD-S575 It has 2...
Car manufacturers donot keep color code. Your best bet is to order a universal adapter. JVC color code can be found in the instruction book. I will attach a picture. upload is not working. email me to jpulickal@gmail.com
Oct 02, 2013 | JVC KD-S570 CD Player
My jvc stereo will not power up but have found the black wire is live ?
hi peter, before you start using the rest of the harness cables find out if the harness you have is a jvc original for your model. the black wire is the ground/chassis cable only for a jvc kd-r411. you mite be using a compatible fitting harness whose " wire colour configuration" is incorrect for your model. cheers.
Mar 02, 2013 | JVC AM FM CD DET FACE CAR STEREO
What wires are for what on my kd-g200
The cables for you In-Car stereo are as follows:
Black - Earth to to the chassis.
Yellow - Live that should be connected directly to the car battery and not the igniton.
Red - To an accessory terminal in the fuse block.
Blue / White stripe - To remote antenna (if fitted)
White / Black stripe - Front left speaker (negative terminal)
White - Front left speaker (positive terminal)
Grey / Black stripe - Front right speaker (negative terminal)
Grey - Front right speaker (positive terminal)
Green / Black stripe - Rear left speaker (negative terminal)
Green - Rear left speaker (positive terminal)
Purple / Black stripe - Rear right speaker (negative terminal)
Purple = Rear right speaker (positive terminal)
That covers all off the cables that you should have with the car stereo.
Apr 11, 2010 | JVC KD-G200 CD Player
Car-stereo wiring diagram TOYOTA Tarago 1986
any local car stereo shop can sell you an adapter harness for $10-$15. This is a much cleaner and better way to go than cutting your factory harness.
Mar 14, 2010 | Car Audio & Video
I have the same model cd player (jvc kd-s575) and I need to connect this straight to a 12v battery. What is the best way to do ths and what wires are positive and negative?
im bit confused, if you are going to use this radio in car, or outside, using car battery.....? anyway, this how you hookup all the wires..
+YELOW WIRE,- DIRECT FROM BATTERY TERMNIAL..12+
+RED- MAIN WIRE..CONNECTED TO ACC/IGNITION SWITCH, ALSO 12V+
-BLACK- NEGTIVE, GROUNDING WIRE 12V-
WHITE TO WHITE/BLK----SPEAKER
GREEN TOGREEN---SPEAKER
GREY TO GREY-----SPEAKER
PURPLE TO PURPLE------SPEAKER
if you are using outside the car using car battery, then you can twist yellow and red togather..for postive 12v+
Oct 26, 2009 | JVC KD-S570 CD Player
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Car radio connections
Red wire to acc fuse
yellow= b+ fuse
blue= to amp amplifier
white= +left front speaker
white/black left front - front speaker
gray= + front right
gray/black= - front right
green= + rear left
green/black= - rear left
purple= + rear right
purple/black= - rear right
black = ground---to car metal
orange with white line to illimination
Apr 15, 2009 | JVC KD-G110 CD Player
JVC KD-S570 CD Player Logo
944 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
