Question about Whirlpool GEW9250 Electric Dryer
How to Side Vent a Duet GEW9250 dryer?
I have a WP GEW9250 Duet dryer. I need to convert it to vent out the right side. I need to know where I can find the instructions on how to do this...the manual is useless for technical detail!
  • UnderTheRose Feb 13, 2008
    The installation instruction in the manual is useless...it says to have your installer set it up for you...not easy to do when YOU are the installer. I have found out there is a kit that WP sells...
    President:
  • Whirlpool Master
  • 2,651 Answers
You dont need a kit, get under ther with an elbow and some solid vent tubes, a little foil tape and your in, should be a prefforated knock-out where it will vent through side,
Posted on Feb 22, 2008
    President:
  • 1,314 Answers
Look in your maual under instalation instruction if you dont find it there then reply to me and ill find it for you
Posted on Feb 12, 2008
  • robert samples Feb 13, 2008
    ok let me take a look and ill get back with you
My whirlpool duet electric dryer will turn on run for a minute than turn off and smells hot
Check the dryer vent,some times they will get stopped up with lint causing the dryer to shut off on high temperature.
Mar 03, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer, dryer gets to hot, even on delicate cycle, clothes to hot to touch
may be the heat sensor(around 10Kohm) or the heater relay on the control stuck in the on position.(new control)
Oct 29, 2010 | Whirlpool GEW9250 Electric Dryer
I have a duet electric dryer. It isn't getting hot air
This video shows how to get into the machine. Your heater slides out and is easy to replace by removing the bottom panel. Looks like this:
Jul 30, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer vent
some have a knock out plate on the right or left side. then you buy a conversion kit, which is an elbow and couple of pieces of pipe.
Jun 20, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
May tag it heat up but no air is comming of the hose that leads out side
Your vent is propably restricted with lint. Have entire dryer vent system cleaned. Make sure first that the dryer is blowing ok by taking hose off back of dryer. If air comes out dryer without hose attached but no air out vent when hose is attached then the vent hose or duct work in house is clogged.
Feb 02, 2010 | Whirlpool GEW9250 Electric Dryer
Want to vent the dryer out of the right side not the back.
take the back off. knock out the piece you want and move the exhaustr hose connector to the new hole
Mar 25, 2009 | Whirlpool ET8CHEXSQ Dryer
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
Duet Dryer vent re-routing
Dear sbrown183,
Welcome to fixya,
You asked for the procedure to re-route the vent from the rear to the left side.
Here below are the instruction you requested for venting both the rear and or the sides.
If you follow these manufactures directions and you will be fine
You will find them on pages 11, 12 and 13.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208533582.pdf
Let me know how you do.
Please remember to leave a solved rating!
Thanks for using fixya
Huuum
Sep 04, 2008 | Whirlpool GEW9200L Electric Dryer
Long drying time on whirlpool duet dryer
check your vent it must be clean 4 inches all the way out make sure the damper door on the vent hood is clean easy way to track down a vent problem is to disconnect the vent and run a load if drying time improves then you have a vent problem if not reply to me and we will look at something but the vent is number 1 cause of your problem
Jan 09, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
1,794 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
