Question about RCA OPAL M4001 MP3 Player
Help can't get this thing to work
Tried formatting it now says it is full what is the deal
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 28, 2008
Need help working my camcorder/camera
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
Jul 16, 2012 | Mitsuba DV777 Camcorder
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
When i try to copy the music files from my computer to SonicStage, it gives the error "Cannot find music files not registered to SonicStage. Error Code 00007180."
Make sure that all the music is MP3 format it seems to me that you have one of those deals where you have to pay for the music if this is the case they have a format that is not working with you player or storage unit. Check to see if you are full or redo the drivers for it. John
Jan 28, 2011 | Computers & Internet
I was using windows vista on Toshiba Laptop. I got a problem on it then I try to format C: then try to install Windows XP but got a problem. When try to install XP I can get message like Stop:...
Please note before I continue on that XP can not always be placed onto a system that had Vista as some drivers and hardware will refuse to work.
You may be having an issue w/ the boot manager.
I would suggest running the windows xp recovery console this will give you a dos like screen. Once there you can do a lot w/ the system I would suggest trying to rebuild the bootmanager.
If none of this works. You should try a full not a quick format off the install screens or you can run a win98 boot disk and access the partition and format commands.
Please post your findings in as great of detail as possible.
I believe at this time the bootmanager may be confused as to if its dealing w/ visita or if its dealing w/ xp. The boot manager uses a part of the harddrive outside of normal storage to control parts of the OS loading procedures.
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 23, 2010 | Toshiba Satellite L515S4960 Notebook
My Sanyo hd1010 camera repeats format sdhc card on start up
its a fult with in the camcorder program chips only thing you can do is get it repaired or buy a new camcorder witch may work out cheeper
Oct 27, 2009 | Video Cameras
When i plugged my usb micro, autorun is not
You just need to format it. Not a quick format - the full thing, using FAT32.
Good luck,
mousemusic
Jul 01, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SDr250 .mod+VISTA+WideScreen
some codec will not be supported by vista movie maker. As far as i know it still cant deal with mod very well. U have to use a prefessional tool to deal with mod files.
Try Pavtube MOD Converter which can convert mod to any other formats u want. And the output file can be played in full screen mode and audio-video is surely in sync.
For more:
http://www.pavtube.com/mod-converter/
Jun 21, 2009 | Panasonic SDR-H250 Flash Media Camcorder
How to format nokia 6233 mobile phone
switch off your mobile first. Hold the following 3 keys simultaneously. Call button(green button), * and 3(number button)
With there 3 keys holded by u, simultaneously
switch on your mobile.
Feb 26, 2009 | Nokia 6233 Cellular Phone
Xacti VPC-HD1000 "Problem with SD card" "FORMAT / FULL FORMAT"
This card is not compatible with your camera try another brand!
This should fix ya! ( ( all sd cards may look alike but they are not!)
Dec 14, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
RCA OPAL M4001 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
