Monitor problem It's monitor display settings pop up automatically again & again. Menu buttons are not working.my moniter model is hcm780m of hcl company please give solution for my problem
  • rajivsingh Mar 02, 2009
    My monitor model is LG Flatron L227WTG. The monitor menu pops up automatically and keeps changing the setting by itself making it too bright sometimes and sometimes too dim.
    Any idea whats happening to these monitors?
    Scholar:
  • 198 Answers
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
Contrast Ghost
This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Good Luck
Sep 02, 2009 | Computers & Internet
Monitor problem
Not a solution but I am having the same problem. Besides this time, it says on my screen, and half of my screen is outlined by a blue box and it a bit darker than the other half. My Monitor buttons do not work either ... (Besides the turn on/off)
Feb 24, 2009 | Computers & Internet
HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Jan 23, 2009 | Computers & Internet
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
CRT MONITOR display
It sounds like this monitor may have what's called the "Windex syndrome" in TV repairs. If someone cleans the screen with a spray cleaner and it drips down the face, it can get onto the circuit board and cause intermittent button troubles. Sometimes it's possible to clean off the corrosion from that area, but the most reliable fix is to clean the board, replace the switches, and remove, check and if necessary replace any resistors connecting to the switches.
Nov 18, 2008 | HP Compaq FS7600 17" CRT Monitor
Monitor display problem
It seems that your menu switch is short. If you can open up the Monitor check out the connection of your switch and the related components, clean with Spirit or alchohol, check out the switches, if found faultty replace it. That should solve the problem. Good luck.
Dec 05, 2007 | Relisys TL 700A (White) 17" LCD Monitor
Computers & Internet Logo
957 people viewed this question
Alun Cox
David Payne
David Payne
