Question about Samsung DVD-HR720 DVD Recorder
Power outage - recorder broken?
Hi people,
Last night we had a power outage, after a lamp popped / short circuited. When we got the power back on, the DVD recorder didn't work properly any more. The status is as follows:
- The fan at the back still works, and the display clock is shown. (it does have power). Also, the SCART signal loop from the antenna to the TV does work.
- However, the clock doesn't change, it remains at 18:00. Additionally, the machine doesn't respond to any button (Stand by / On, etc.), nor does it respond to the remote, or the 'reset to factory settings'-button (press >>| for 5 seconds).
Has anybody had the same problem, and if so, what should I do?
I could open it up myself, but I'm not an expert. However, I'd prefer the cheaper solution to the expensive expert ;-)
Thanx for any help in advance!
Hi;
One week ago we had the same problem. And I Send the machine To Technical Service. They Changed the harddrive and reprogrammed the mainboard. Now it plays&record very well. I think U must send it to Samsung Technical Service.
Best Regards.
Firat
Posted on Mar 08, 2008
Power cut last night and cannot get my TV to power up.
First check your circuit breakers. Also,If you are capable, open the TV and check the fuse inside. The power outage and the sudden spike in power might have tripped the breaker or blown the fuse. Good luck!
Feb 17, 2016 | Televison & Video
Monitor blinking after power outage
Check the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Thermador Oven E10 error message--due to power outage?
HI. During the power outage, there may have been a power surge. This has shorted your main control board. This E-10 is indicating that this is the issue. This code represents a failed control board. It must be replaced, in this case. Once replaced, the unit will return to its normal operating status.
Dec 08, 2009 | Ovens
My Vip622 was down this morning, no power outage,
Unplug the unit from the mains for at least an hour, then plug it back in again and try to boot it up.
Good luck
Jun 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Lamp Indicator is Red
a 41 error code for a short is usually caused by the power PWB. The power board will need to be replaced
May 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Recorded programs in english come out in Spanish
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
Feb 06, 2009 | JVC AV27F476 27" TV
Same problem as others. Sony KDF-E55A20-while watching TV, screen goes black and sound leaves too! Will come back on in a few seconds...but continues this cycle. The green light stays on.
You really need a tech to check the error codes recorded in the TV to be sure. You could have a bad lamp driver, but I would want to see if any error codes were recorded
Sep 25, 2008 | Sony KDF-E55A20 55 in. LCD Television
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Samsung DVD-HR720 DVD Recorder Logo
160 people viewed this question
Henry  Thomas
Henry Thomas
