I have a 2000 vstar 1100 custom who has cranked just fine.today i cranked it..it started but cut off cause i didnt give it enough gas then would not start back..the starter has a whine to it..my husband says it soulnds like the starter is not disengaging...IDK help
sounds like you may have a starter not disenguaging but it may be caused by a bad battery need a bit more information to give you a solutionsounds like you may have a starter not disenguaging but it may be caused by a bad battery need a bit more information to give you a solution
is it the starter will not start the bike now or that it is "whining" when he engine is running? little unclear.is it the starter will not start the bike now or that it is "whining" when he engine is running? little unclear.
You can't post conmments that contain an email address.
Hook a jumper cable from the negative battery post to any grounding point on the starter and try starting. If it starts then the problem is in your ground. Remove and clean both ends of the cable as well as the spot they connect to. Reinstall ground cable and try starting. Hope this helps
I too have a 97 buick skylark custom, that hasn't been cranking. Heres what I have figured out so far, so you may have the same problem. Heres the first question - Is the theft system light flashing when you try to crank the car? Cause if it is, it means the car isn't wanting to recognize your key as the correct key which is causing the car to go into tamper mode which disables fuel to the engine, in which case you have to turn the key back to the start position and wait for the light to stop flashing then try to crank it again.
P.S. i'm not sure why this other thing would be a problem but i lost my gas cap right before this started happening and someone told my that might trigger the sensor, do you have yours?
Could be a starter issue, or a wiring issue. Check for power at the starter when the button is pressed. If you have power, you need a starter, if not, trouble shoot the electrical system.
