Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Won't spin or wash
I took the front panel off the motor is'nt turning What could it b?
  • 2 more comments
  • happymarried Feb 12, 2008
    It feels up with water then when it washes it seems like it goes in circles when it washes but when it goes 2 the spin it does'nt spin like it suppose 2. 2 spin the water out.What could it b?
    The washers seem like it goes in circles when it washes but when it gets 2 the spin It does'nt spin like it should 2 get water out
    It smells like the belt is burt after it trys 2 spin It does'nt spin real fast like it suppose 2
    It moves it just does'nt move Fast!
  • 240 Answers
Could be a number of issues really. Lid switch could be bad, timer may have issues, motor could be out as well. Does it make any noises at all when you go to start it (like a hum or something). Lets get some other information before we jump in. Try a different timer cycle. Does the unit fill with water, then stop? Does the dryer work normally? Tell me all you can, whats its doing, when it does it, etc. Will get you fixed, just dont want you to replace something that doesnt need it. Talk to you soon.
Posted on Feb 12, 2008
  • James Greene
    James Greene Feb 12, 2008
    Ok, when it is in agitation, does the inner basket turn real fast? Sounds like you may have a transmission that has went bad. On the bottom of the transmission, there is a bearing that will only allow the transmission to turn one way. When that lock bearing goes bad, the motor cant get torque to move the belt. This in turn burns a hole in the belt. The best way to get a hint if this is what happened is to watch the inner drum (not the agitator) when in agitation, and see if it moves kinda fast, or spins quickly in agitation. Let me know what happens next. Talk to you soon.
  • James Greene
    Ok, maybe should remove your belt, just push in on the tensioner pully, then slide off the belt. Check it for burns, tears, etc. Let me know what the belt looks like, then try to turn the pully by hand. Also see if the motor pully turns freely. Let me know.
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
Hotpoint washer won't spin or agitate and has black soot - is clutch out?
The motor coupling is attached to the shaft of the motor. The "soot" is probably the result of the coupling shredding prior to failing
Oct 09, 2012 | Hotpoint Washing Machines
Won't spin fills and drains water if i manually turn dial
Direct drive or belt drive? If belt drive then thats easy, motor belt or pulley. Direct drive? motor, ,,, maybe.
Jan 11, 2012 | Frigidaire GLTF1240A Front Load Washer
Washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 09, 2011 | Kitchen Ranges
Model no. 23832, won't spin, lid switch is good and so is motor coupler. HELP
heatman101
Aug 09, 2011 | Kenmore 2383x
3 area rugs wee washed but would,nt spin out . E20 kept flashing. I took all but 1 rug out machine finished cycle but still didn,nt wring out This has never happened before
there is a lint screen inside the water pump hose(the one that goes from the outer tub to the pump). if you have a port or access door to get to it remove it, if not you may have to remove the front panel to get to it. you could have debris blocking the drain and causing the computer to delay the spin process.
Feb 09, 2011 | Frigidaire Affinity ATF7000E Front Load...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Frigidaire GLET1142CS0 washer wont spin
I Changed the TUB belt and now it spins.
Jun 10, 2008 | Washing Machines
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
63 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
