Question about XFX GeForce 6200 Graphic Card
When i restart my computer everything seems to come on, but i get no signal on my monitor. i unplug it and sometimes that work. now its taking longer. plz help me
  • aws266 Aug 30, 2008
    i uninstall the old one and wanted and install the the new one and wanted to install the software for the new one but nothing comes in my screen. I used the old one and nothing happening. what i have to di it's is just balck screen(the windows starts normally but then everything just disapperas)
  • 407 Answers
Hi your graphic card setup properly and conect graphic slot ....in your monitor conector .......
Posted on Feb 12, 2008
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
www.dell.com/support/article/us/en/04/SLN129390?c...l...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
forumarray.com/no-signal-message-on-monitor-and-pc-gets-restart-1421...
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from forumarray.com
Jan 27, 2016 | Dell Computers & Internet
Video Problem
That seems to be the monitor running a test. It might do that if it isn't receiving a signal from the computer. Make sure the cable is plugged into the tower and the monitor.
The graphics card could be bad, or the motherboard or power supply. Has it ever worked before? What changes were made? Was there lightning in the area or a power failure?
Turn the computer off and unplug it, and the monitor. Wait a few minutes, then plug everything in and restart. Hopefully it isn't a permanent hardware failure.
A test to narrow down the cause would be to use a different monitor or computer to see where the problem lies.
Oct 31, 2013 | HP Omni 100 PC
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
I turn on my computer but my monitor says there is no signal
hello, try to unplug the cables on your desktop, then plug it again, sometimes its loose, or sometimes the power supply on your computer is not functioning properly.
Nov 02, 2009 | Computers & Internet
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
Mar 27, 2009 | Samsung 941BW LCD Monitor
Acer Model AL1916W A reads no signal after being on for 1 hr
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Jan 22, 2009 | Acer AL1916W 19" LCD Monitor
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
Acer AL1912 sometimes doesnt start
Try reseating your cable connections. While you have them off, take some compressed air and clean both the connection ports on the back of the computer and cable connections. Check to make sure there are no bent pins on the cable connectors. If you know how, you might also want to open your computer case and reseat your video card and clean your system out with the compressed air. Make sure your computer is completely shut down properly and is unplugged from the outlet when you do this and before you work inside the case make sure you touch the metal side to discharge any built up static electricity you may have so that it does not cause damage to the sensitive components inside your system. If possible you might want to take the monitor and connect it to another computer system, if it works properly on that system, more than likely it might be your video card. Hope this helps
Jun 25, 2008 | Acer AL1912 19" LCD Monitor
No signal - out of range
Start the computer.
After the ios info page/motherboard page is gone, start to press F8 a few times.
If you still get to the point that you see the Windows Logo loading screen, then press reset and try again.
If you have done it correctly, you will get to the Windows boot page.
Select Safe Mode and start Windows
Go to the video properties page by right clicking anywhere on the screen and adjust the video mode to 640x480 (or as low as it will go)
Restart the computer and see if that solves the problem.
If not, then do the same procedure, but go into system properties and unistall the video card.
Restart again, and install the drivers if needed.
Hope it helps.=)
Apr 23, 2007 | BenQ FP71G+ 17" LCD Monitor
XFX GeForce 6200 Graphic Card Logo
Top XFX Computers & Internet Experts
David
David
Alun Cox
Sulkhan Abesadze
Sulkhan Abesadze
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
