Question about Acer AL1913 19" LCD Monitor
ONCE ON WILL STOP ON
HI WHEN I TURN POWER SUPPLY OFF TO MONITOR ,IT WILL NOT COME ON ..... IF UNPLUG POWER SUPPLY SEVERAL TIMES IT COME ON AND STAY ON HOPE YOU CAN HELP
  • 180 Answers
Repair the power supply.
Posted on Apr 21, 2008
It has power but no sound and no picture. TV turns on and power button flashes about 12 times and then stays blue.
Hi Dustin,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Apr 27, 2015 | LG 50PG25 50 in. Plasma HDTV
Lg w2753v monitor shuts off
Make sure the power cable is firmly plugged into the monitor and into the wall. If so, you may have either a marginal power-supply to the monitor or the monitor electronics may be failing.
If there is a power-brick (adapter) on the power cord for the monitor, make sure the wires going in-to and out-of that are not loose or damaged. Consider a new power cord before condemning the monitor.
Dec 28, 2017 | Computers & Internet
The monitor lamp stays yellow after pc turn on, and i need to unplug electric supply 2 or 3 times to make the monitor work, also some times the lamp turns blue but no picture or backlight and in addition...
Unplug it, otherwise more damage will be done to other circuits. It has bad power supply due to bad caps, replace them in a set with the correct type.
See my pictures here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 30, 2011 | ViewSonic VX2235wm LCD Monitor
My monitor started to give me problems when I first turn it on I have to push the power button several times before it will stay on it's the samsung syncmaster 203b
you need your power supply reaired. the capacitors go bad. remove the covers and look at the power supply reeplace any leaking and or crowned capacitors
Jan 01, 2010 | Samsung SyncMaster 203B LCD Monitor
I have exactly same problem
Sound like your display is having issues with the inverter board. When the power supply detects a short circuit, it turn off by itself. When you try several times, you may be able to "bypass" the circuit protection but the damaged parts still having problems. This issue may be related with the DELL display issues.
The display needs to be fixed by someone with experience in electronics repair.
Sep 29, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
19"chimei Lcd. Screen stays black.
probably power supply, dac-19m015, 2200uf bad capacitor.
Apr 26, 2009 | Microsoft ChiMei CMV938D 19" Widescreen...
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
Power Problem
The hissing noise on your speakers is because of arcing. Do not try to operate repeatedly or you may do severe damage. The most likely culprit is the inverter board but you will have to disassemble the monitor to find out. Any loose connection that results in an arc will create noise on speakers. Hissing is usually a result of the high frequency/ voltage output small enough amperage to not blow your power supply If it were a DC arc you would just get a one time pop.
Jan 02, 2008 | HP Pavilion F1703 17" LCD Monitor
Monitor
-Turn off both computer and monitor
-unplug monitor from computer(still plugged into power supply)
-turn on computer and monitor(monitor is still unplugged)
-After computer is on for about 30 sec. plug monitor into computer
-turn off both monitor and computer(now connected together)
-turn on monitor then computer and should be good to go!!!
Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
Acer AL1913 19" LCD Monitor Logo
186 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
