Question about Philips Magnavox 51MP392H Rear Projection Television
Bad speaker/ access panel removal
I have a bad speaker in my tv and can't find a way to get the access panel off to change it out. Anyone know how to get it off? TIA.
    President:
  • 1,284 Answers
As far as I know the speakers have to be removed from the back. Its a poorly designed cabinet.
Posted on Feb 13, 2008
My Samsubg PN42 was built in Sept 08 so no more warranty. Speakers rattles with low frquencies. OK when listening through receiver. Does anyone knows aproximate cost of replacing speakers in a flat plasma...
The problem is inside of the tv. Your speakers are probably fine. The problem in most sets I have found is that the internal parts/Brackets are vibrating particularly at the lower frequencies. You must insert non conducting foam and duct tape to immobilize any moving parts. With the back of the set off, Tap the chassis with your finger and you will hear where the vibrations are coming from. Repeat taping and inserting the foam until the vibrations stop or are minimized to acceptable levels. You can also adjust the custom audio with the equalizer to cut the base frequencies. This is a common problem. In some cases I have found Bad speakers and need to be replaced and is really simple to do with the back panel removed. Once you see the speakers you will how simple it is to replaced the speakers.
Apr 15, 2010 | Samsung Televison & Video
Tip
Many Mitsubishi projection TVs have bad control panel switches. These switches...
These switches fail and lock up the TV's computer, disabling everything.
If you can unhook the control panel, the TV will work fine with the remote.
Remove the speaker grill. Pull on the sides, it should come loose with a little effort.
Remove the access panel by removing the 4-6 screws using a philips screwdriver.
Follow wires from control panel inside to the connector labeled "DZ".
These will be the thinner wires, not the thick ones that go to the video jack.
Unhook this connector and the TV should work with the remote.
You can replace the switches, but the Mitsubishi buttons sometimes will just fail again. Using another brand of switch may be more reliable.
Better to just use the remote and let the buttons be useless. Nobody uses these usually anyways.
Some models will require you to unplug the TV for a minute, and then plug it back in and wait about 2 minutes before the TV will work again (reboot the microprocessor inside). The biggest issue with repairing your TV by unplugging the control panel like this, is that you no longer have the green LED on the front panel. Many Mitsubishi TVs will flash the green LED for about 90 seconds and then the TV is ready to turn on. Without this panel connected, you just have to remember that you need to wait 90 seconds after plugging in AC power before the TV will be functional.
If this fix does not help resolve your "dead" set issue, you likely have a bad power supply or bad signal board. The way to know is to check the +5 volt standby line inside. You can check this on the same connector to the front control panel for an easy check, without opening up the back. Just check all the pins and one of them should have the +5 volt standby sending power to the switches. Use the outside of the video jack as your cold ground. Thanks and good luck!
on Jun 19, 2010 | Audio Players & Recorders
HOw do I replace front speakers on 1991 brougham?
you'll need to remove the door Panel to access the door speakers,the door panel will be held in with several screws.
I believe the Front Door Speakers in a brougham of that year are 4x6".
Mar 04, 2010 | 1991 Cadillac Brougham
INSIGNIA TV WITH ILIVE BAR. 1 SIDE WORKS
Try swapping your cables from the sound-bar to the TV. If the sound still only plays through one channel but the channel has changed from right to left or vice-versa, then you have a bad cable.
If the performance is the same, connect a different device using the same cables to see if it's the sound bar input or the TV output.
Once you know where the problem is (the sound bar, the TV, or the cables) you'll know what unit needs repair or replacement.
It is entirely possible that a solder joint for the sound-bar has come loose. A soldering pen would easilly fix this if it's a bad joint/connection.
Hope this helps!
Dec 25, 2009 | Insignia 200W Stereo Receiver
Change my rear speakers in 2005 pontiac g6 . We do not know how to get to the speakers from inside the car. or how to drop them down from inside the trunk. thanks for your help
you have to remove the rear window panel, do so by "unclipping" it from inside the trunk. once removed then you will have access to the speakers
Oct 25, 2009 | Car Audio & Video
I am getting no response when i push the power button. I have a mitsubishi medallion 65'' 1080p tv. This just happened out of nowhere. there is no blinking light nothing. i noticed that there is power...
Front buttons . Remove the lower front speaker covers/panels by pulling . Then unplug connector ZF to the keypad . Then wait 3 minutes and try to turn it on with the remote . You may have to remove the access panel to find connector ZF (just follow the wiresdown from the front keypad). Don't touch , turn or break anything else while inside the access panel!
Let me know if that works
Oct 21, 2009 | Televison & Video
The remote operates all the units except for the TV's vol, channe
There are 2 possibilities: either you have a stuck front panel button, or the remote sensor is bad.
You can eliminate the button issue by removing the front speaker grill and access panel and disconnecting the button assy wiring harness.
There is a plug/socket connection there that you can easily disconnect. If after disconnecting the control panel, you still have no remote, its the sensor. Its located behind the screen assy mounted behind the CRTs. You will have to remove the screen assy to get to this.
If you're not up for this, a service company will charge you $300 or so to replace the sensor for you.
michtech
Feb 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Anyone know how to pop the radio out?
try removing the speakers from the cab and trying known good speakers. That way you will know if there's any power or not.Otherwise you will have to remove some of the panels on the dash to gain access to the reciever. After you can open upa space to access the reciever, it is only a matter of removing a feww screws and the nut at the back that holds the reciever stable.remove radio fuse before doing anything.
Nov 06, 2008 | 1998 Jeep Cherokee
Mitsubishi TV VS-45607
Good Day;
This model is known for the front control panel going bad. You could unplug it, control panel cable, from the front of TV, by removing the speaker grill, and just use the remote.
Good Luck, big IRISH.
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Tv mitsubishi ws55311
Remove front lower speaker grill,then remove access panel =
unplug white connector ( goes to front controls )......Does the set
work now with remote ?...= bad tactil switch on front panel......T.
Apr 23, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
