Question about Nokia 6255i
Nokia 6255i will not turn on
My friend borrowed my phone and the battery died on him. Since then the phone will charge but will not turn on? anyone know what the deal is?
  • Anonymous Jan 09, 2009
    my phone keeps on resetting after someintervals it just dont get registered to the network
  • Nokia Master
  • 13,433 Answers
Probably noting wrong with the battery, might be a hardware issue, I recommend you take the phone for analysis to a phone shop.
Posted on Feb 12, 2008
Will not charge battery
Two issues here as far as i know,
1) either the battery is old and died and hence doesnt charge.
2) the charger cable is bad or the adaptor is bad due to which the charging fails.
Solution
USe the same phone to another charger (borrowed from a friend or family member) and see if the phone charges. Or use the same battery in another (again borrow) device and charge the phone and see if it is working. you will know what the issue is. hope this helps.
Aug 21, 2013 | Cell Phones
CANNOT CHARGING MY NOKIA N97, THE INDICATOR LIGHT IS NOT BLINKING, ONLY DISPLAY NOKIA AND THEN OFF
Please check your battery, it might have already been damaged. My battery was already bloated, and hard to put the back cover when I encountered the same problem. You may also borrow a battery, from a friend just to verify it. Before checking the battery, I did some verification using a known good nokia charger from a friend, and still could not charge it.
P.S. I replaced my battery after using my N97 for more than 3 years.
Feb 05, 2011 | Nokia N97 Cell Phone
My nokia n95 wont turn on even when charger is in phone in mains i havent used phone for a while because the battery died quickly even when i hadnt spoke to anyone
better you go to nokia service center make a good check up or try by replacing with nokia s original battery and charge for it continusly for upto 6 hrous with out switch on the phone ..... try it
Feb 02, 2010 | Nokia N95 Cellular Phone
Cant get phone started
You may have let your battery fully drained before you recharge it. If that is the case, it will never charge and turn on the unit. Using a voltmeter, check the voltage. Any voltage lower than 3 volts will not allow your battery to be charged no matter how. You need to "shock" it before you charge it. To do so, use a 9 volt battery and connect its terminals to the battery terminals with same polarity. That is, positive to positive and negative to negative. Do this for one minute or until the battery gets warm. Insert the battery then charge. If it successfully charged but dies early, you need to replace the battery. You may opt to borrow a friend's battery to directly check if it's really the battery.
Sep 26, 2009 | Cell Phones
My sony ericsson K550i cellular phone won't switch on even the battery has been charged for hours...
Sep 26, 2009 | Sony Ericsson K550i Cellular Phone
My htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Sep 25, 2009 | HTC Touch Pro Smartphone
Broken housing on 6255I
The best suggestion is to bring your phone to the nearest Nokia Care Center. Or you may wanna check any cell phone stores. There should be an available casing/housing in any cell phone stores.
Have a good one!
Jun 23, 2009 | Nokia 6255i
REPAIR NOKIA 6255I
bagaimana sih format nokia 6255i, menggunakan *#7780# masih aja tidak hilang applikasi yang ada di hp
Jan 17, 2008 | Nokia 6255i
Nokia 6255i (or 6256i) Verizon
check the tracks of mic to headphone
Dec 20, 2007 | Nokia 6255i
Nokia 6255i Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
