Question about Brother MFC-7220 All-In-One Laser Printer
Pc-Fax Receiveing problams.
I'm using windows xp pro ..
but i cant receive pc fax on brother mfc-7220?
Pc-fax sending is ok..
pls help me.
  • ireneyeo Feb 20, 2009
    Fax will print out when receive but soft copy is not save to pc. error message pop out as 'There is not enough empty space on your hard disk. Please delete any unnecessary date files the restart PC-FAX Receive again. (PR003)' I've already check my drive which still have more than 50% free space. Pls check.
Buy a different printer brother sux
Posted on Mar 18, 2008
I have a MFC it will not send a fax
You need an ANALOG phone line for faxing, not DIGITAL.
Mar 19, 2010 | Brother MFC-7220 Plain Paper Laser Fax
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
Not receiveing Fax.
Make sure the receive mode is set to Fax only
1-Press Menu/set,0,1
1-receive mode
2-Press up or down arrows and select Fax Only
3-Press Stop/Exit
Apr 03, 2009 | Brother MFC-7220 All-In-One Laser Printer
Fax problems
I think you just not plugged with the phone/fax cord.
Please check the cord is connect or not.
Mar 16, 2009 | Brother MFC-7340 All-In-One Laser Printer
MFC 7840W, fax not sending or receiving
Is your phone line DIGITAL? Fax machines are ANALOG devices.
Jan 15, 2009 | Brother MFC 7840W Printer
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Fax problem
I guess you run win xp.
Did you install the whole mfl-pro suite? If not, do so. Check the installation by clicking installation check within the brother programm (start/progr./brother/installation check).
After a good installation press start/progr./brother. There you will find a pc-fax set-up. With that you can fax out of your pc thru the mfc.
If you want to receive fax on your pc you have to change settings within the machine . see handbook software which is part of the installation software cd how to do the right settings (chapter I 6 pc-fax)
Oct 13, 2007 | Brother MFC-5460CN All-In-One InkJet...
PC faxing
you have to install the mfl-pro suite given to you by cd. After installation go to START/PROGRAMM/BROTHER/PC-FAX SETUP (Guess you run windows). Or simply use the paperport software: drag your document and drop it to the faxsymbol. If you dont have it, download (153mb) from brother homepage of your country. Pleas notice: the faxprinter of xp wont work anymore after installation of the brother drivers (but you have the bro drivers then installed for fax :) )
Oct 08, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-7220 All-In-One Laser Printer Logo
836 people viewed this question
James Cagle
James Cagle
Jim Keysor
