Question about Kenmore 84152 Electric Dryer
Makes squeaking noise after running for about 10 minutes
The dryer starts out running fine then about 10 minutes into the cycle it makes an annoying squeaking noise. Can anyone tell what might be wrong.
  • Henry Feb 13, 2008
    My lint filter is in the door frame. The unit has the pulley not the slider. At first i thought the spring for the pulley was rubbing the belt but that is not the case
  • 240 Answers
Another thing to check would be the idler pully down near the belt and motor assembly. On some Kenmore's and Whirlpool's, they have installed slider idlers instead of wheel idler pullys. It will look like a half-moon shaped metal part. If you have this, spend the $13 for a roller pully (Part Number 691366
). Do you have a lint filter in the door or on top of the unit? They do have some other parts on the unit with the lint filter in the door. Let me know what model you have, and will get your squeeking stopped.
Posted on Feb 13, 2008
  • James Greene
    James Greene Feb 13, 2008
    Ok, on these dryers there is also two rollers in the front as well that the drum rides on. If you have the front kick plate off, take some WD-40, and you will see the rollers in the back. Spray the center supports on both rollers. Then look up in the front and you will see the same rollers. Give them a spray as well. On your idler pully, spray the center of that to. See if that stops it, if not, let me know, and will go from there. Talk to you soon.
  • 958 Answers
You can check a lot of things. the motor itself, the rollers on the back, and the main bearing at the center of the drum. you can apply any lubricants to all of those rolling parts.
Posted on Feb 12, 2008
At the start of the drying cycle the dryer would squeak for a few minutes as it heated up the squeaking would stop ;now the dryer will not turn on, only hums whn the start button is pushed..HELP!!
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 30, 2011 | Dryers
My Maytag Neptune dryer, works fine until the last 5 to 10 minutes and then starts to make a loud skreeching noise. Suggestions??
heatman101
Jul 18, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a gas dryer Maytag Dependable Care Model 6 cycle about 11 yrs old...Has a steady squeak as it runs , seems to be getting louder . Everything on the dryer seems to work fine other than this...
heatman101
Jul 14, 2011 | Dryers
The dryer will make a loud scretching noise like metal rubbing on metal and then after about 10 minutes the dryer will shut off and when you try to restart pushing the timer/start button, it just make a...
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 31, 2011 | Dryers
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
Squeak
check what is called an idler or tension pully. lubricating these can somestimes help but only a temporary fix. actualy its not a fix. only makes it quiet. replace them or call service these parts are easily accessable
Apr 25, 2009 | Maytag Neptune MDE4000 Electric Dryer
Replace the dryer drive belt and the dryer tub rollers.
Mar 01, 2017 | Kenmore Dryers
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Kenmore 84152 Electric Dryer Logo
191 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
