Question about Hoover L2310 GUV Central System Vacuum
Low suction I have a Hoover central vacuum system. I've reset the fuse box, checked the fuses, all of the lines are clear and there are no holes for escaped air to travel out. The filter has been cleaned as well. The vac works well with high suction when hooked directly to the unit, however when using any of the indoor connections there is extremely low suction. The machine still turns on so I do not believe it is an electronic issue. I have troubleshooted the issue as best I could and would value any additional input you could help with in resolving the low suction. Thank you.
    Top Expert:
  • Hoover Master
  • 13,735 Answers
You probably have debris partially clogging in the line coming into the unit
Posted on Apr 21, 2017
    Top Expert:
  • Hoover Master
  • 79,186 Answers
I suspect the hoses are plugged with debris.
SOURCE: HOOVER STEAM VAC SPIN SCRUB
Check the flexible hose that comes down from the handle.  Look for a crack where it plugs into the base unit.  (visible once you open the handle up and remove the cleanable catch basket)
Posted on Oct 22, 2007
reddevil6
  • 1673 Answers
SOURCE: upholstery conversion
Take out the duct in front of the tank (#3), the hose end will have a duct on it that you insert in its place. This provides the suction for the hose. Don't forget to put that duct you took out back in place, or you won't have suction when you use the steam cleaner.
Posted on Feb 12, 2008
  • 294 Answers
SOURCE: Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
Posted on Mar 15, 2009
galati2k
  • 281 Answers
SOURCE: Wont suction the water
the suction channel is probably clogged.the suction channel goes right up the middle ,you can see it by looking through the cover.probably a lot of hair and dirt stuck up inside.there are some screws on the botton you need to take out then the cover will come off.seperate the 2 pieces of plastic and you will be able to clean the channel.please leave feedback
Posted on May 01, 2009
  • 190 Answers
SOURCE: hoover steam vac has no suction
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Make sure the tank lid is aligned to the recovery tank to seal, and assure the square panel is in place on the front of the recovery tank that connects the vacuum of the tank to the clear nozzle plate.
Posted on Mar 23, 2010
Vacuum not clogged but has low suction
Check all the pipes, there could be something stuck in them which hasn't come out.
Also check the base of the vacuum if there is something stuck in the base.
Lastly check if there are any leaks in the pipes.
Also check the suction without using the handle, by pulling the pipe in your hand and see if it has more suction.
Apr 28, 2014 | Hoover U6630-900 WindTunnel Bagless...
I installed the Hoover Wind Tunnel Central Vac in my new home. After connecting the wall outlets and successfully turning on the system from the hose control, I discovered there is lots of air flow t
I would recommend checking your wall outlets where the hose plugs in for any type of clog in the tubing. If the vacuum itself has great suction but when you go to the wall outlets that is probably something in the hose that is stuck. If cleared it will most likely have excellent suction throughout the entire system in the house.
Jul 21, 2012 | Vacuums
Nutone cv353 unable to stop
You may have a stuck relay or one of your access port switches may be bad. According to the owners manual: "A complete check of all Wall Inlet and Power Unit low voltage control lead connections (external yellow leads). Turn system off by removing fuse or tripping circuit breaker at
house fuse box."
Dec 27, 2011 | Broan-NuTone CV353 Central Vacuum
Poor suction in system - I have used shop vac to suction all three receptacles. Have checked bag and cleaned everything. Still poor suction. I have one receptacle in garage that works perfectly. Must...
Have you checked the hose for clogs or leaks. Clogged and leaky hoses are an area of concern with any central vac. Unless you hose has a hose sock, then wear and tear from constant rubbing on floors and other surfaces will result in holes and cracks. Pulling the hose can also result in leaks where the hose attaches to the handle and intake connector.
Mix some dish soap with water.
Use shop vac to blow air through hose, with other end capped or "clogged".
Apply soap solution to each end of hose.
If bubbles form, this indicates leakage. Hose will need to be replaced.
Oct 25, 2010 | Broan-NuTone CV450 Central Bagged Central...
Suction not working on vaccuum.
Check for a blockage in the hose, or a tear / hole in the hose between the "pleats"
Jun 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
Suction is not as strong
you may have a clog in the lines.
check some Maintenance Cloths and run them through your lines and you should see some improvement.
If you still are having problems, contact your local vacuum shop and see if they do maintenance calls for central vacuums.
Apr 15, 2010 | M&S Systems FX-3000 Bagged Central System...
Low suction
1) Have you checked the filter? If it is clogged your suction will be low. Also, you could have a pipe loose where you can't see. Make sure that you can get a coin to go all the way through the hose. make sure the suction motor ( the unit ) is coming on.
2) Call the repair man.
Aug 10, 2009 | Electrolux Central Vacuum
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
May 05, 2009 | Electrolux Central Vacuum
Low suction when using attachments
Have you cleaned the foam filter? located above the dirt tank after you remove it. the manual can be downloaded from the web site at www.hoover.com ; sounds like an obstruction in the hose or elbow on the back of the unit. the hose can be cleared with a broom hadle when you take the hose completely off the vac.
Jan 17, 2009 | Hoover U5780900 Bagless Upright Cyclonic...
Hoover L2310 GUV Central System Vacuum Logo
83 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
