Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Dish drawer DD601v2
Top draw stopped working. swapped bottom draw control box with top but made no difference. Returned control box to bottom draw and now bottom draw no longer heats and shows error (red and beeping) at end of cycle which I guess is when attempts to heat. Just removed bottom draw looking for fuses - where are they?  Found what looks like some sort of fuse loose inside bottom of machine.  Has a little button red outer ring and white inner that clicks so must be some sort of switch bt where does it go. Help.........
  • hrd51 Jul 13, 2008
    Hi, I am looking at a friend's faulty Fisher and Paykel DD601v2 dual
    drawer dishwasher. It had lost power in the bottom drawer about a
    month ago and now the top drawer has done the same. Removed and opened
    up the control modules. Both control modules have the following
    symptoms: Signs of high voltage tracking (arcing) between legs of diode
    D710 and capacitor C708 (black sooty traces) on the legs closest to the
    edge of the circuit board; Fuse F701 is open circuit; Bridge
    rectifier diodes D704 and D707 are short circuit. On one control board
    I cleaned up the sooty tracking marks and replaced the fuse F701 (slow
    blow) and all four bridge rectifier diodes (D704, D705, D706, D707)
    with 1N4007 (they originally were 1N7005). Reinstalled controller and
    dishwasher worked for one complete dishwasher cycle. Next day found
    main panel was dead again (no power). Opened up control module and
    found: evidence of more high voltage arcing between diode D710 and
    capacitor C708; Fuse F701 blown again, and this time bridge rectifier
    diodes D705 and D706 blown. Can it be that voltage controller U701 (a
    TOP227Y device) is faulty too? I'm not sure how to test U701 (any
    ideas?). Note that C708 appears Ok (it is not short circuit) and diode
    D710 seems to test OK (conducts in just one direction). Anyone have
    any ideas? Note, there is NO tech troubleshooting guide or schematic
    inside the dishwasher and none would be supplied by the local Fisher
    and Paykel "Customer Care". Very unhelpful. Any suggestions out there
    for a component-level repair suggestion? This machine cannot be the
    only one that has this fault. My e-mail is jbauer@webone.com.au. I
    will be happy to post any solution that I receive that works to help
    others. Cheers Aussie John
  • Gary Davd
    Gary Davd May 11, 2010
    What error codes are you getting?
    Champion:
    Habit-Forming:
  • 279 Answers
When you put the good board in the dead draw it put the fatal fault into that controller now both are stuffed, sorry.
Posted on Nov 30, 2011
    President:
  • Fisher and P... Master
  • 2,651 Answers
Thats tub home sensor switch, mounts to rear right of cabinet and senses drawer closing along with little black box with red switch should also have a little metal actuator( this is what usually breaks off switch), each drawer uses their own. unistall from cabinet and theres an access panel strictly for replacing theses switches
Posted on Feb 23, 2008
How to restore power to top drawer
http://www.scribd.com/doc/6462163/DD601V2-Manual
Sorry some more information as to what the cercumstances are may help ?
Try this link anyway , Cheers
Sep 28, 2014 | Fisher Paykel 24 In. Panel Ready Double...
Top drawer can not be open
If this is a double drawer dishwasher and bottom drawing is functional but top drawer won't open means the controller on top drawer is faulty or power circuit is locked. If turning the mains power off and back on makes no difference then controller could be the problem. One way to test is to take the controller from bottom drawer and replace that in the top drawer. This requires a lot of patience and experience with electronic stuff. If you are not brave enough to test then call the technician. The controller is about $200 to buy. Make sure the mains power socket is taken out before working on the dishwasher internals.
FISHER PAYKEL DISHWASHER DD603 Parts
Feb 10, 2014 | Fisher and Paykel Dishwashers
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a 10 year old dishdraw (Model No DD601v2). It is displaying a fault message "F1" on the top draw display and will not start. What fault is this indicating?
Normally F1 should display in both drawers.
But this is a bit unsual. Please confirm if you are still able to operate the bottom drawer.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top drawer will not take in water. The tap symbol flashes. The bottom drawer is working perfectly. I have cleaned and checked it - no obvious obstruction in the drawer.
1 the inlet valve need replacing its bottom of the draw bit tricky to replace it to check it just unclip bottom draw to the side disconect the hose from the inlet top draw valve and turn it on for a sec see if water pumps out make sure you got small bucket if that works finne. 2 its the pump under neath the dish draw thats very tricky took me 1 hour to do
Sep 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top draw on our dishwasher isnt working .bottoms fine.wont start just beeps and the numbers /display is jumbled
If this has stopped working suddenly then most likely the controller on the top drawer has packed up. Before panicking, take a clean moist kitchen wipe and clean the edges inside around the drawer including the touch buttons inside. Sometimes the grime confuses the controller. Best of luck.
Oct 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top draw dead bottom draw works fine
the heter plate has a fuse molded in it change the heater plate
Jul 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
I havve a Fisher and Paykel Dishdrawer model No. DD601v2. The top draw was stuck in the out position. I fear that the top of the shell casing of the dishwasher is rusted and is blocking the smooth...
When the machine operates a lid comes down on the top of the drawer. This may be jamming.
On the side near the front at the bottom there are 2 plastic slotted screw heads, turn these to horozontal and pull out the "screws" this will release the drawer from the runners and you can lift off the drawer and possibly see whats jamming.
Jul 03, 2009 | Dishwashers
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
1,176 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
